hhr blower fan
Old 07-31-2017, 04:23 PM
My bet is a dying fan motor. Drive it far enough until you hit a bump in the road that gets it spinning.
You could try starting the car again and if the fan doesn't come on, reach under the dash and tap the motor housing with a wrench or something. That may tell you if the motor is sticking or not.
firemangeorge is online now
Old 07-31-2017, 04:58 PM
i dont know's Avatar
blower fan
hey I changed the relay fan still wont work .
i dont know is offline
Old 07-31-2017, 05:09 PM
hi . I bet that fan motor is a dealer item ? I hope not
Old 07-31-2017, 05:20 PM
Merged into the original thread. Please keep your posts for your fan issue in this thread.
whopper is offline
Old 07-31-2017, 05:42 PM
Technical Moderator
No. Most parts stores can get them. eBay. Amazon etc. For instance: http://www.ebay.com/itm/Depo-335-580...tZY4LR&vxp=mtr
What's wrong with GM part? Many of the vendors on eBay are in fact GM dealerships.
Here are some useful links:
https://www.chevyhhr.net/forums/%22h...ghlight=blower
donbrew is offline
Old 08-02-2017, 02:54 AM
a ?
hi , not sure what you mean , please explain ,does that mean if I want to post on this subject again start over again?
Old 08-02-2017, 03:06 AM
No - just keep your posts on this subject in this thread.
The one I quoted (hey I changed the relay fan still wont work) I merged into this thread. You had originally opened a new separate thread from this one and posted it there.
whopper is offline
Old 10-25-2017, 10:10 PM
rmc51's Avatar
My 09 is doing the same
My 09 LS panel is doing the same thing. It is not the fan motor, it is not the resistor, it is not the #4 fuse in the fuse box. The relay is on the BCM. The BCM is behind or under the radio. I need to open the center console to get/find the BCM, so I,m looking for a post on how to get to the bcm/radio area. Working on it.
found two posts that may relate some as to what I'm talking about
https://www.chevyhhr.net/forums/prob...54/#post783972
https://www.chevyhhr.net/forums/prob...85/#post826715
rmc51 is offline
Old 10-26-2017, 07:34 AM
It could be the control panel.
https://www.ebay.com/itm/2007-2011-C...6981538?_ul=CA
Oldblue is offline
Old 10-26-2017, 08:30 AM
Technical Moderator
illustrations are in your Owner Manual. The BCM is the inside fuse box on the passenger side.
Online Owner Manual available through a link in my sig.
donbrew is offline
mgeinitz
01-30-2014 05:42 PM
wrusprod
02-13-2009 07:15 AM
Tony_SS
01-09-2008 08:37 PM
nss79
11-16-2006 02:39 PM
Quick Reply: hhr blower fan
