HHR lights Flash and horn beeps without reason
My wife accidently put my 2009 HHR factory electronic key chain in the washing machine with the laundry two days ago. Seemed to worked fine afterwards. Today my vehicle's lights started flashing and the horn started beeping without cause. It has done this twice now in a 12 hour period. Is this issue related to the key chain and has had anyone else had this problem?
Jessica L.
Chevrolet Customer Care
BE VERY careful when removing the battery. Take the circuit board out of the silicone pad and gently push the battery out/in. DO NOT apply ANY upward pressure to the battery cage, or you will need the "cold solder" thread to repair the fob.
I'm having this same problem. If you haven't been close enough to the car to listen to it while it's doing it, the door locks are cycling open and closed...like you're continuously hitting the lock button. Done it about 4 different times now. Tried to clean the fobs but continues to do it. Checked all of the fuses and nothing out of line. So yeah, it's a problem that my car is randomly unlocking itself in the driveway.
It actually cycled the locks up and down while driving a couple of weeks ago. I'm thinking it might be a bad door switch? ANY help would be appreciated!!!!!!
emill713
Jun 20, 2013 10:27 AM
