HHR not wanting to start after engine replacement
Old Oct 6, 2016 | 09:10 AM
mastersanka2020's Avatar
Question HHR not wanting to start after engine replacement
We just got a 2011 HHR from an auction. We got an extra engine with it. Both engine needed work. It turns out that the engine that came in it after being worked on would not start. The second engine only had a good crankshaft so we kept that. Anybody have any ideas why it wouldn't start
Old Oct 6, 2016 | 09:28 AM
Welcome to the site, possibly the crank sensor or dead battery or loose or broken ground wires
Old Oct 6, 2016 | 09:41 AM
............. or dead fuel pump, bad sensor (too many to list), bad ECM etc. etc.. Without a list of things you have already checked, anything we can offer would be a wild guess.
Have you checked to see if it is getting fuel? How about spark? Done a compression check?
Old Oct 6, 2016 | 04:13 PM
celblazer's Avatar
What is no start? Does it crank? If so: fast, slow, normal? Got spark? Fuel in tank(yes it happens)? Key matched to car/ECU?
I think the crank sensor has to be learned if swapped.
Old Oct 6, 2016 | 04:51 PM
The crank sensor needs to be learned but will not prevent a start if not learned, just a CEL.
Are the ECM, BCM, sensors and injectors all matched?
Should we assume that you know what you are doing or that you are a novice re: modern computerized cars.
Old Oct 10, 2016 | 08:46 AM
Talking
Turns out the key we got needed programed(knew that). But then the car still would not start so had to mess with the electrical system in the front. In the end it was something that we had never touched or messed with that dealt with the battery and grounds.
Old Oct 10, 2016 | 08:53 AM
As mentioned in post #2! Yeah, it lives!!
Old Oct 10, 2016 | 09:13 AM
Runs Real Smooth now. Love the quietness and limited road noise. The turn signal sound is pretty cool.
JLATKY
Apr 5, 2014 06:46 PM
Avram
Jan 22, 2014 11:14 AM
Robb
Jan 15, 2014 10:30 AM
HillsdaleHHR
Feb 21, 2009 02:26 PM
IndyRetroGal
Aug 5, 2008 10:16 AM
