Chevy HHR Network
-   -   High Brake Light OUT, need alt part # for new wiring harness (https://www.chevyhhr.net/forums/problems-service-repairs-42/high-brake-light-out-need-alt-part-new-wiring-harness-67883/)
chaosdsm Feb 22, 2026 07:13 PM
FIXED! High Brake Light OUT, need alt part # for new wiring harness
Anyone know an alternate part number, that will work in the HHR, for either the high brake assembly or ideally just the wiring harness? Been trying to find a replacement wiring harness for the high brake light, all 4 bulbs out, I was able to remove two of them from the old holders, but the holders are very corroded, the other two bulbs are apparently corroded so badly that they will not come out of the holders.
Both the high brake assembly - part # 15287657 - and the wiring harness - part # 10372458 - show as discontinued on the Chevy parts lookup, and I cannot find any in stock.
Alternatively, anyone know where I can find the 921 bulb holders that match those on the high brake assembly so I can make my own??? All the ones I'm finding have a different connector where it would latch into the brake light assembly.
Near-term, I can just pull the assembly out of the LT, but I would rather the LT NOT become just a parts wagon....
Oldblue Feb 22, 2026 07:26 PM
Check eBay or parts yards
chaosdsm Feb 23, 2026 01:03 PM
Found a different part number on the LT high brake wiring harness: GMT100-440 and light assembly 16532491, unfortunately, they didn't help either....
https://cimg3.ibsrv.net/gimg/www.che...216afeb956.png
https://cimg8.ibsrv.net/gimg/www.che...a4fe1a8bca.jpg
Not finding any u-pull-it yards with HHR's nearby, might have to go the ebay route after-all :(
There's some minor corrosion in these connectors too, but cleaned right up with a couple blasts of DeoxIt D5 & Q-tips. Got some LED's to try out! These & the marker lights are tthe only halogen lights left to swap out, except for the lights behind the instrument panel which I would love to swap, but....
chaosdsm Feb 23, 2026 03:43 PM
I had also asked about help finding the individual 921 bulb holders that match the HHR holders.... I purchased 2 sets of holders with slightly different designs that could potentially work... One of the sets came today:
https://cimg2.ibsrv.net/gimg/www.che...701b5ee614.jpg
The boot is hard rubber, it's not a match but it does mostly fit, and turn into the assembly. I would just need some jumper connectors to daisy chain them together, & attach to the electrical socket.
Here they are in the LT brake assembly for fit check:
https://cimg2.ibsrv.net/gimg/www.che...6d4e0d5838.jpg
You can also see one of the LED's I bought to check out, they're smaller overall vs a regular 921 bulb. and decently bright, but only about 50% as bright as my LED brake lights. They are only rated for 200 lumens from SIRIUSLED, they will likely be used for tag lights instead... The other two sets of actual 921 sized LED bulbs coming are supposed to be brighter and have double the LED emitters.
https://cimg0.ibsrv.net/gimg/www.che...1edaba534d.jpg
Here's the new stuff that came today: *not including the brake light harness
https://cimg6.ibsrv.net/gimg/www.che...b474e58fc0.jpg
> A new pair of exact fit H13 LED headlight bulbs that supposedly do not need relays...
> the LasFit brand I've used before and seem to be VERY good bulbs. The 4-pack with 2 rows & 2 columns are exterior bulbs, tag light / marker light combo pack, with 2 white tag light bulbs and two amber marker light bulbs. The other 4-pack are of course interior bulbs. I've been using their 3157 turn/brake bulbs in the LT since 2022 & they are noticeably brighter than the halogen bulbs, plus, they have resistors to eliminate the 'hyper flash' error you sometimes see with LED turn signal bulbs.
> SiriusLED was a cheaper option, but I already see from the design that the LasFit are probably going to be the better interior option with their extra LED emitters and not quite mirror like reflectors to the side of the LED's to redirect wasted side emitting light back downward. But if the LasFit are too bright, then the SiriusLED might be the ticket.
> New Key Fob shell - mentioned in my other thread to fix the worn out fob, just put the board out of the old fob inside & good to go..
Oldblue Feb 23, 2026 04:01 PM
Led s don’t work very well in the third brake light , not enough resistance to allow the cruise control to work properly. You might need a 50 watt resistor
chaosdsm Feb 23, 2026 05:20 PM
Key there is to look for the ones that say "Canbus Error Free" If you look closely at the one in the bulb comparison, the LED has a resistor onboard "24RD", one on each side of the LED bulb, plus 4 additional chips.
LasFit still in package has 6 resistors built in plus a bunch of other circuitry
https://cimg4.ibsrv.net/gimg/www.che...ce4506d934.jpg
Third option that should arrive tomorrow also has onboard resistors. This is what makes them "error free" as to the cars computer, they appear to be standard halogen bulbs.
Still if need be, I can solder in additional inline resistors in the new harness I'm making. This one is just a design mock-up. To conserve space, I'll solder the connections, and if needed, I can de-solder and solder in appropriate inline resistors.
https://cimg2.ibsrv.net/gimg/www.che...86c2257055.jpg
Oldblue Feb 23, 2026 05:48 PM
I’ve had three sets of different source can bus error free bulbs, they all light up nice, designed specifically for third brake lights all failed for the cruise control to work
lazaino Feb 23, 2026 07:38 PM
The resistors go in parallel, not in series.
chaosdsm Feb 24, 2026 11:55 AM
Incorrect, they can go either way.
but probably better using a single resistor if possible.
Crusie control already NOT working, so when I pickup from the dealer after they finish service / recalls, I'll swap out the light, & see what happens!
btw, got the other bulbs in & tested out in the LT: Here are the 4 LED's tested for brightness based on visual observation, don't have a brightness testing rig.
https://cimg2.ibsrv.net/gimg/www.che...a063c7c12d.jpg
I'll probably go with the Auxito for extra brightness in daytime but not overkill, since they seem to be about the same brightness as my LED brake lights.
Oldblue Feb 24, 2026 12:27 PM
I’ve installed these, failed!
https://www.vleds.com/921-6-r.html
