FWIW, both of those are in parallel. The 3 resistors in series are the same as the one resistor, but the resistors are in parallel with the bulb. If someone tried to put the bulb and resistor in series it would really not work.
Originally Posted by lazaino
(Post 959496)
Originally Posted by Oldblue
(Post 959486)
I’ve installed these, failed!
https://www.vleds.com/921-6-r.html Currently a dead point.... All the other rear lights work, and the high brake assembly, with the Auxito red LED's installed, works in the LT, but put the assembly into the LS & nothing. I'm going to go pickup some standard 921 halogen's & see if maybe it's just the LED electronics that aren't working well with the LS??? |
Eliminated fuses as a possible culprit, checked under hood, and right side under dash, all fuses good. All other lights are working, even the tag lights, so looks like I've got to find some broken wiring, but how... everything is wrapped up tightly.
Also, just read that the ESC/traction control might also be tied in? Anyone know if this is true or not? |
Tighten the 4 bolts in the under hood fuse box. They’re 7mm and you need to tighten them past clicking noises, the pins need to be pulled up tightly into the connection.
I check mine every oil change, just to be sure. |
(Post 959542)
FIXED!!!! I must have spent between 1 & 2 hours trying to find the 3rd brake relay, the way it was worded in one post, I had started to think that it was only in the HHR Panel....
Tonight, I finally found a youtube short that showed exactly where the 3rd brake light relay was located. Opened the hood & sure enough, there it was. Grabbed the known good relay out of the LT, put it in the LS, & the 3rd brake light is now working!!!! I'll check tomorrow to see if cruise control is working. I'm starting with the halogen bulbs first just to verify if it works or not before switching to the LED's. |
Awesome, you found the relay, it is kinda hidden away from the fuse box.
let us know about your bulbs |
Cruise Control now works, Auxito LED's do not work with Cruise Control, but it appears the LasFit LED's DO work. I say "appears" because I only had 2 of them to try, pulled two of the four Auxito bulbs, & exchanged them for two LasFit bulbs, and cruise control works under that configuration.
Ugh... the Airbag dash light is back, so no more cruise control till that's fixed :( Unfortunately, the dealer did not show part # for the "connector" they want to replace for $483...
At least Google gives me some starting points.... all done after disconnecting battery of course.
| All times are GMT -5. The time now is 05:12 AM. |
