Hmmmmm, what are the "good" brands of wheel bearings nowadays in the year 2024?
- 2007 LS
- 2.2 liter EcoTec engine
- automatic transmission
- about ~97,500 miles
So I'm thinking about replacing the right-rear wheel bearing since I believe it might be starting to go bad. Was browsing Rockauto the other day but my goodness... what is the deal with sooooo many different brands??
These are the available brands I'm seeing, what brands are considered the "good" ones nowadays?...
- WJB
- Mevotech
- SKP
- Ultra Power
- Durago
- FVP
- GMB
- Centric
- MOOG
- Schaeffler
- SKF
- Raybestos
- Timken
- ACDelco
...and some of these brands have multiple wheel bearing options per brand, including "with anti-lock brakes" and "without anti-lock brakes" in the description, it's just a dizzying amount of choices to sift thru
Thoughts or experiences with these brands?
- WJB
- Mevotech
- SKP
- Ultra Power
- Durago
- FVP
- GMB
- Centric
- MOOG
- Schaeffler
- SKF
- Raybestos
- Timken
- ACDelco
Your 2007 LS might’ve been ordered with antilock brakes, but usually they don’t. If you see wires going to the hubs then you have antilock brakes or look at the RPO code sticker in the glove box for JL 4 and JM 4 that would indicate antilock brakes.
depending on your budget Moogs or SKF would be a good choice, I have installed cheap economy hubs they lasted about 25,000 miles , I’ve installed Timken they went to about 80 thousand miles.
I guess I'll have to go look for it next time I'm out in the parking lot
Definitely buy bearings with a respected bearing company name on the box, not stuff from a car parts company line. Rolling element bearing manufacturing has a crazy number of variables, and there are way too many ways to make bad bearings.
Exception would be GM OEM. AC Delco, maybe.
SKP is a bearing company in India and has only been around since 1992. Their visual identity strikes me as deceptively similar to SKF. Not on my trusted list yet, but still might be a better bet that some budget broad-line car parts companies.
I just installed Mevotech TTX hubs on the BlackSwan, one was defective in the wire harness for the abs speed sensor, RockAuto replaced it free of any charges even the shipping!
