Hood bracket ball broken
https://cimg9.ibsrv.net/gimg/www.che...6316a1c038.jpg
Im not sure whay to call this part but I replaced my hood struts and the ball broke on this one, does anyone know where I can find a replacement part. Thanks so much |
Here’s the part number 15291408
Try eBay or a parts yard |
Originally Posted by Oldblue
(Post 959451)
There are no GM dealerships in Arizona?
Drill out the old broken ball stud. They make a replacement stud that bolts into the hole.
I saw those studs on eBay.
I drilled out and replaced a couple on my HHRs. They were all on the hatch struts.
I don't know about the hood struts, but the hatch struts have a different size ball at each end. Make sure you measure the right ball diameter. I threaded the hole for the stud, or you can use a nut. I got mine from this place: Struts and Parts Steve |
The bracket is listed as obsolete.
| All times are GMT -5. The time now is 06:37 AM. |
