Horn Issue
Sorry to bother y'all for such a silly question, but under which front fender does the horn live?
I noticed yesterday that the horn wasn't chirping when I locked my car ('07 2400 LT) and then discovered it wasn't working at all. I don't know whether it's a loose wire or if the horn's crapped out, but I need to find it first. My Haynes manual says to "Remove inner fender liner," but neglects to point out driver's side or passenger's side. Much obliged. |
Have you done the obvious parts first? Fuse, relay etc.
Passenger side https://cimg6.ibsrv.net/gimg/www.che...114711c0fb.png |
I don’t like to contradict you Donbrew, but the horn is on the driver’s side under the headlight area
https://cimg3.ibsrv.net/gimg/www.che...afcc6745f.jpeg |
donbrew: In short, No, I haven't looked at anything yet other than the shop manual.
Is the relay in the fuse block? |
In the under hood fuse box, the horn fuse is #60
https://cimg8.ibsrv.net/gimg/www.che...30a6d00d7.jpeg |
Thanks for the diagram.
As you were responding to this, I was under the bonnet. Fuse #60 is intact, and I swapped Relay #55 with another, but the horn remains quiet. Next step is the horn itself I guess. |
Yes, I replaced mine with a two tone set from a 2012 Camaro SS, plug and play harness
Originally Posted by Clyde
(Post 905776)
As you were responding to this, I was under the bonnet. Fuse #60 is intact, and I swapped Relay #55 with another, but the horn remains quiet. Next step is the horn itself I guess. Got current, the horn is either bad or not grounded. No current. Somewhere between the horn itself and the steering wheel.(steering wheel button, clock spring or wiring) |
Those wire frame pictures got me again!
Here is the schematic: https://cimg0.ibsrv.net/gimg/www.che...eb5c1ce237.png |
Just to follow up on the horn issue I raised a few weeks ago.
(Thanks Oldblue, the horn is on the driver's side.) After getting things apart, I discovered a terrible splice-job on the horn's wires. I have no idea what would have cut the wires requiring the splicing in the first place, but it was a crappy job and as soon as I started jiggling the connections, the horn beeped its approval. A couple of Sta-Con splices and a few zip ties later, no more horn problems. Thanks for everyone chiming in. |
| All times are GMT -5. The time now is 01:54 AM. |
