loud snap sound
Old 10-03-2009, 09:28 PM
pluked21's Avatar
Question loud snap sound
I have a 2006 and really like it even though it does have some quirks. The radio will come on sometimes when I use my auto lock entry. I also at time will have a loud snap/pop sound when I trun the car on. My delearship has changed out every component of the radio front to back. If it could only happen to then when they have it. Has anyone had the same issue? How was it fixed?
I noticed some owners have had issues with the brakes. I just spent close to $500.00 to replace disk and routers, 38,000 miles.
pluked21 is offline
Old 10-04-2009, 08:26 AM
JoeR's Avatar
GM has a TSB for the radio problem. The BCM needs to be reprogrammed. No parts replaced. You may want to contact a competent dealer who knows this.
JoeR is offline
Old 10-04-2009, 10:06 PM
pluked21's Avatar
Question
OK, not being mechanical savy, what is TBS and BCM? I do think they had tried the reprogamming. Last replacement was the amplifier in the rear
pluked21 is offline
Old 10-04-2009, 10:23 PM
oneton's Avatar
TSB is tech service bullitin.
BCM is body control modual ? Go to the Dealer and tell them to look for a TBS to reprogram the BCM if they don't Know about it tell them to look for it or go to a competent dealer who knows this.
oneton is offline
Old 10-05-2009, 08:36 PM
pluked21's Avatar
Thanks, I will let them know. Nice bike!
pluked21 is offline
Old 10-06-2009, 10:07 AM
shadowwar's Avatar
Mine had the pop noise every once in a while enough to blow out your ear drums when you went to start the car. The flashing of the bcm didnt help. I had xm also and my station would reset back to channel 2 if i left it on a xm station when i shut off. Mine was the XM module itself. They replaced it and all was fine after.
shadowwar is offline
Fox Hat
02-07-2014 07:39 AM
F-16C
08-05-2013 02:01 PM
rad white panel
10-04-2009 09:09 PM
beachbum1970
7
03-29-2009 08:31 PM
SSROADSTER
06-26-2008 09:48 PM
Quick Reply: loud snap sound
