I just replaced the front right wheel bearing and
Old Sep 2, 2012 | 12:02 PM
STony G's Avatar
I just changed the front right wheel bearing and now I get the abs and traction lights and service traction message. Did I do something wrong?
Old Sep 2, 2012 | 12:25 PM
2007HHRLT's Avatar
Check and make sure the ABS sensor was plugged back in. Try to disconnect the battery for 10 minutes and is should reset the computer and see if it comes back on.
Old Sep 2, 2012 | 12:56 PM
ChevyGuySS's Avatar
thats all that happened, unless the hub you put on is bad, you can bring it to advanced and they will check the code for free
Old Sep 2, 2012 | 01:40 PM
STony G's Avatar
I just came back from exchanging the new unit, in the hope I was just lucky receiving a bad unit. It is a good thing, replacing the bearing does not take too much time.
Thanks for the tip on resetting the computer.
Old Sep 2, 2012 | 03:05 PM
STony G's Avatar
Well that didn't work . I have a service traction message and the abs & no traction icons.I replaced the replacement and let the battery sit for 20 minutes...just in case. Any other thoughts, should I get a code reader?
Old Sep 2, 2012 | 03:13 PM
2005HHRauto's Avatar
What's the part# that you are using.
Old Sep 2, 2012 | 03:32 PM
Wheel bearings are covered under the Power Train warranty..
You profile shows a 2002 hhr tho ?
Old Sep 2, 2012 | 07:06 PM
Hmm, a 2002 HHR. But my guess would be a damaged connector anyway.
Old Sep 2, 2012 | 10:23 PM
ChevyGuySS's Avatar
i dont think hubs are covered under powertrain anymore...
Old Sep 2, 2012 | 10:43 PM
I think they sure are..
https://www.chevyhhr.net/forums/problems-service-repairs-42/07-09-10-11-powertrain-parts-coverage-list-22231/
