Ignition switch problem?
Old Feb 28, 2013 | 10:32 AM
Lee3333's Avatar
For the past few years, whenever I hit a large bump or pothole, my engine shuts off. I have to shift to neutral and turn the key to start the engine again. I noticed it also shuts off when I unlock the tilt wheel and bang the steering column up or down. I don't think it is the keys, since the engine doesn't shut off when I wiggle them. I bought a new ignition switch (the electrical part, not the key tumbler). It looks simple to replace, but I was wondering if anybody here has changed theirs yet.
Old Mar 4, 2013 | 05:24 PM
Lee3333's Avatar
Well, I just changed it and it went well. The 2 torq screws holding the switch in place did not have enough room to get at them with a regular handle, so luckily I had a small ratchet handle that came with a kit for working on guns, and the hex hole fit the bits I had.
Old Mar 4, 2013 | 05:41 PM
Lucky's Avatar
Glad you were able to get it changed out let us know if it fixes your problem.
Old Mar 5, 2013 | 06:47 AM
SpaceCowboy's Avatar
its possible you could have a broken ignition wire or a pin coming out of the back of the ignition harness especially if when you tilt your wheel you are having this problem
Old Mar 8, 2013 | 06:44 PM
Lee3333's Avatar
I did a visual check and all wires seemed fine. So far, no stall.
Old Mar 11, 2013 | 09:39 AM
the wire will break inside the protective casing...you have to test continuity while moving the wires around or tilting the wheel
Old Mar 18, 2013 | 06:40 AM
Lee3333's Avatar
I tried that when the cover was off, and it did not shut the engine off. I notice that when I turn the ignition key, it is much firmer with the new switch. And so far, no shut off over bumps...I hope I did not just jinx myself.
hurst2001
Nov 7, 2021 09:02 PM
frustrated
Oct 30, 2014 03:53 PM
alexrckid
GM Recall Campaigns
Apr 9, 2014 09:21 PM
probablecause
Mar 26, 2012 04:45 PM
fsc44
Mar 7, 2012 04:02 PM
