Intake cam position actuator
Does anyone else have rigid holes under and beside both the intake and exhaust cams actuators?
Hi Trevor, :welcomewagon: to the forums!!
Holes in what? |
They are holes in the head. They appear to be from the factory but i just want to make sure.
Here's a picture from the actuator solenoid valve replacement how-to thread. Is this what you're seeing, or do you have the valve cover off?
https://www.chevyhhr.net/gallery/files/4/8/6/5/cs8.jpg |
Here's a shot with the solenoids out and the valve cover off.
http://www.ramscyl.com/images/GM22_Direct-Inj.gif |
And here's an exploded view. #207 is the gasket that seals the area of the actuators(236 and 237) and the center of the valve cover(around the spark plugs) to the head.
http://www.wholesalegmpartsonline.co...11GM00-596.JPG |
What is a "rigid hole"?
Reply
The holes he asks about may be the 4 to 6 threaded screw holes on the valve cover? I believe they fastened a plastic shield cover that went over the coil packs keeping dirt & debris out??
Yeah, could be I use the 2 front ones to thread the studs in to support my air filter box, they are also used for the coil pack on 2006 models
https://encrypted-tbn0.gstatic.com/i...9QEBkT2YWdI38A |
