Front Struts Replacement
Old 05-16-2018, 03:24 PM
SlickRick2's Avatar
I recently replaced the front struts on my '09 with ACDelco "Ready Struts". I watched a couple videos on YouTube; highly recommended. Just thought I'd pass on that the job is really easy EXCEPT:
I sprayed the three lower mounting nuts a couple times with Nano Universal and Kano Aerokroil (both are great) before starting the job. I didn't think to spray the six upper studs under the hood. The first of these studs sheared right off which was OK. Two of the other nuts came off fine; the other three studs broke at their welds and just spun. It took a diamond cut off wheel on my Dremel to clut the nuts off. I swear those nuts are made of titanium!
I used my electric impact gun on the bottom stuff and the nuts came right off. The sway bar links were replaced previously, and the Moogs have a hex "nut" on the back, so I was able to hold the stud with a wrench. Otherwise, the OE link stud will probably just spin.
Final note, an oddity on the new struts: the upper nuts on the driver's side take a 13mm socket but on the pass. side, take a 12mm socket. Maybe they aren't all that way, just a last effort to mess with me.
SlickRick2 is offline
Old 05-16-2018, 03:35 PM
Thanks for the heads up to spray those upper nuts and studs, I'll be doing my struts soon. I just checked, all 6 originals require a 1/2" socket.
How much ride improvement are you feeling?
RJ_RS_SS_350 is offline
Old 05-16-2018, 03:46 PM
Technical Moderator
Are the studs the same size? Did one side have built in washers? The nuts have a really tiny torque, 15 lb.ft.
I have seen the built in washer nuts being a larger size.
donbrew is offline
Old 05-16-2018, 04:07 PM
SlickRick2's Avatar
Much improved ride; I didn't realize how "bouncy" it was. Changed the rear shocks, too.
I think the studs are the same, but I'll check. The nuts look identical with the built-in washers. Yes, torque is very light.
Old 05-16-2018, 04:22 PM
My OEM upper nuts were 13 mm , perhaps the upper bearing plate had been replaced, my new plates from Moog were 12mm
Oldblue is offline
Old 05-16-2018, 04:41 PM
SlickRick2's Avatar
The OE's were both 13mm, the two new ACDelco's are, curiously, different. I just checked and the studs are the same; it's just the socket size is different. Maybe one is just a much different production date or something. Both came from Rockauto; fully assembled no chnage of spring, bearing, etc..
Old 05-16-2018, 06:29 PM
hurst2001's Avatar
How do you like them ? Price on a set ?
hurst2001 is offline
Old 05-16-2018, 06:38 PM
SlickRick2's Avatar
Ride is great; about $125-130 each. Cheaper than Amazon.
Trex08
27
02-21-2017 07:59 AM
Alexwsilver2010
13
03-17-2014 01:47 AM
barfan1
01-29-2011 07:40 PM
hvrod
11
04-28-2007 11:14 PM
ny5112
01-06-2007 09:31 AM
Quick Reply: Front Struts Replacement
