Intermittent Cruise Control Outage: Yet Another Post!
Thanks everyone for all the help. I found the relay last night and it seemed a little loose. I re-seated it and today my CC seemed to work without any problems but I did not drive far. This weekend I will have an opportunity to take my HHR on the highway for a bit of a spin. Will see what happens when CC is engaged. Fingers crossed!!
Will post what happens or doesn't as the case may be.
Thanks again!
Meesch
Thanks again!
Meesch
Ran the car with no CC issues for about 20 or so minutes and then CC spontaneously disengaged and also whilst re-positioning myself in the seat and if I pressed down on the left "foot rest" area of the driver's side floor pan. Due to this, I am of a mind that the issue is with the wiring harness.
Again thanks for all of the suggestions of what/where the problem could be. Very helpful to me!
Is it possible the wrong bulb was used for replacement? Is it possible the brake lights are staying on intermittently, for any number of reasons like the brake pedal not fully returning every time, due to a missing or inadequate spring or some other reason like stickiness, or that the switch is sticking?
