I don't have a lock issue per say but I do have a FOB issue.
Every once in a while my key fob wont want to work on my '10 SS. Other times it works perfect. Is this a known issue? |
Originally Posted by AC66Bronco
(Post 645682)
(Post 645682)
Every once in a while my key fob wont want to work on my '10 SS. Other times it works perfect. Is this a known issue? Michelle, Chevrolet Customer Service |
yes my fobs have both been replaced well after warranty for a huge charge. but they can be soldered. According to my dealer it is not a matter of if but when they will need work. But other than that what a great ride.
Battery connection?
Hmm guess I will look into it. Thanks guys.
And ty for who ever started my own thread :) |
That was a community effort AC66Bronco, between your humble Moderator(me)and ChevyMgr who is schooling me in "Moderator 101".
It was better to spin you off into a separate thread to open it up for discussion and move it into a better area on the forum. |
I think that I remember that the '10 SS has the "extended" remote, that means an antenna mounted on the right rear window that could get mucked up by overzealous window cleaning, or if not that then a dealer probably needs to pull the headliner down to check connections then reprogram the RCDLR.
Originally Posted by 843de
(Post 645788)
Originally Posted by donbrew
(Post 645802)
Just popped open onf of my FOBs.. Solder joints are fine.
| All times are GMT -5. The time now is 07:14 AM. |
