Key fob not working...
Old May 24, 2012 | 10:25 AM
ATLsilverSS's Avatar
Originally Posted by AC66Bronco
Just popped open onf of my FOBs.. Solder joints are fine.
i think if the battery is weak or the connection is weak then the key fobs don't work. i think that is what's wrong with mine.
Originally Posted by donbrew
I think that I remember that the '10 SS has the "extended" remote, that means an antenna mounted on the right rear window that could get mucked up by overzealous window cleaning, or if not that then a dealer probably needs to pull the headliner down to check connections then reprogram the RCDLR.
Haven't heard of that one. Maybe it's on the auto trans only. Don't have one on my 5 speed.
Old May 24, 2012 | 11:39 AM
jimpennjr's Avatar
I've had to have two fobs replaced from my dealer. The solder is fine and a new battery was in and still didn't work. Most likely the carbon on the rubber side of the fob is no longer making the contact. Ebay has new inserts for $2.50 shipped. Ordered one and it worked great. Good luck and keep us posted.
Old May 26, 2012 | 02:24 PM
Thank you for sharing what you have found to fix the key fobs. I hope you are continuing to have them working for you.
Have a happy holiday weekend.
GiasDaddy2010
Jan 9, 2014 02:03 AM
JCJSS
Nov 3, 2013 06:21 PM
gsl54
Jun 19, 2013 10:35 AM
ChevyGrlAlways
Aug 24, 2008 10:58 AM
