Key Ignition
The key isn't supposed to come out if the car is On or if the gear is in anything other than park, right?
Because mine doesn't. It comes off at anytime when I pull it out. What can be the problem? P.S, (recall hasn't been done) |
The key is not supposed to come out unless the ignition switch is in the off position.
That was the very first recall on 2006s, not even related to the newest recall.
I doubt you’ll find a GM dealership in your country that will preform the recall work, all these years later.
https://plants.gm.com/media/us/en/gm...-ignition.html You might find the pieces to replace in the recall. |
The danger is that you can also move the gear selector out of park without the key and brake interlocks; meaning a dog or child can pull it out of park and drift away.
Originally Posted by donbrew
(Post 912793)
It was a good 20km drive. |
| All times are GMT -5. The time now is 09:52 AM. |
