knock sensor?
From what I understand, the knock sensor is actually a sound detector (like a microphone) that picks up differences in the noise level (engine knock) under the hood, then advances/retards the timing. In most cars it just bolts onto a bracket attached to the engine block, usually looks like a small black block of carbon with a couple of wires attached.
i looked at the pics and diagrams, its just a bolt with sensor on it... as soon as the CEL pops again ill get the code.. right now only having one car dont really want the tick noise to be something serious.
I am guessing that you mean P0325 and P0327.
Here is an easy way to get info about OBDII codes: www.obd-codes.com/(your code here). Or just type the code into google.
Both of these codes if they are what I'm guessing at say to check all your wiring from the sensor, your ECM may be bad, the sensor may be bad. You need to find out what the factory resistance is supposed to be then check your sensor.
I believe that all of this info is in your Service Manual.
Amber N.
Chevrolet Customer Care
arclightzero
Jun 16, 2010 12:20 PM
Lone Ranger
Aug 7, 2007 10:09 AM
