Knocking noise when reaching 4p mph
Hi have this problem with my hhr 2008. When i am reaching 40 mph it hear a hard knocking and the car shake a little too. We change struts. Sway arm bushing. Check brake pads. But nothing help. Does anyone had the same problem
Welcome. How many miles on the car? Have you checked the lower control arm bushings? There is a big bushing at the rear of the control arm that is known to wear out at high mileage.
Now, what would you like your name that you registered as changed to? The ×’'× ×™×¤×¨ יפה that you have chosen is not acceptable. Please select a more appropriate name and our Oldblue will change it for you. |
Welcome to the site, could be hubs. |
