List of Diagnostic Trouble Codes for 2008-2010 HHR
Old Apr 4, 2008 | 04:25 PM
ChevyMgr's Avatar
List of B & C trouble codes for anyone wondering what they mean.
DTC Description
B0012 Driver Frontal Deployment Loop Stage 1
B0013 Driver Frontal Deployment Loop Stage 2
B0015 Left Front Seat Belt Pretensioner Deployment Loop
B0016 Left Roof Rail Deployment Loop
B0019 Passenger Frontal Deployment Loop Stage 1
B0020 Passenger Frontal Deployment Loop Stage 2
B0022 Right Front Seat Belt Pretensioner Deployment Loop
B0023 Right Roof Rail Deployment Loop
B0052 Deployment Commanded
B0053 Deployment Commanded with Loop DTCs Present
B0081 Passenger Presence System
B0083 Front End Sensor 1
B0085 Left Front Side Impact Sensor
B0086 Right Front Side Impact Sensor
B0090 Rollover Sensor
B0158 Ambient Air Temperature Sensor Circuit
B0283 Electric Rear Defrost Circuit
B0685 Security System Indicator Circuit Short to Battery
B1000 Electronic Control Unit (ECU) Performance
B1001 Option Configuration Error
B1008 Calibration Data Not Programmed
B1009 EEPROM Checksum Mismatch
B1011 System Disabled Information Stored Invalid Serial Data Received
B1019 System Configuration Error
B1025 Left Front Audio Output Circuit
B1035 Right Front Audio Output Circuit
B1045 Left Rear Audio Output Circuit
B1055 Right Rear Audio Output Circuit
B1259 Antenna Ground Circuit
B1287 External Amp Control
B1325 Device Power 1 Circuit
B1370 Device Ignition 1 Circuit
B1380 Device Ignition ACCESSORY Circuit
B1424 Device Voltage Low
B1441 Device Ignition OFF, RUN, and CRANK Circuit
B1480 Battery Rundown Protection Circuit
B1516 Battery Current Sensor Performance Signal Invalid
B1517 Battery 1 Voltage
B2455 Cellular Phone Microphone Circuit Malfunction
B2470 Cellular Phone Antenna Circuit Malfunction
B2476 Cellular Phone Select Service Switch Malfunction
B2482 Cellular Phone Select Switch Range/Performance
B2483 GPS Sensor Circuit Low
B2484 GPS Sensor Circuit Open
B250D Left Rear Door Unlatch Low Control Circuit
B250E Right Rear Door Unlatch Low Control Circuit
B2530 Front Fog Lamps Control Circuit
B2555 Passenger Compartment Lamp Control Circuit
B2580 Headlamp High Beam Control Circuit
B2625 Display Dimming Pulse Width Modulation (PWM) Output Circuit
B2645 Ambient Light Sensor Circuit
B2705 Gearshift Unlock Circuit
B2750 Horn Relay Output
B3006 Hood Ajar Circuit
B3031 Security System Controller In Learn Mode
B3055 No Transponder Modulation or No Transponder
B3060 Unprogrammed Transponder Identification Code Received
B3105 Keyless Entry System Key Fobs Not Programmed
B3109 Keyless Transmitter Low Battery
B3110 Keyless Entry Transmitter 2 Low Battery
B3111 Keyless Entry Transmitter 3 Low Battery
B3112 Keyless Entry Transmitter 4 Battery
B312A Door Latch Actuators Enable Relay Control Circuit
B3265 Trunk Relay Output
B3715 Front Wiper Relay Drive Circuit
B3716 Front Wiper Relay Drive Circuit Range/Performance
B3717 Front Wiper Relay Drive Circuit Low
B3718 Front Wiper Relay Drive Circuit High
B3719 Front Wiper Relay Drive Circuit Open
B3794 Cruise Control Function Request Circuit
B3903 Stop Lamp Relay Circuit
B3935 Transponder Authentication Error
B3948 Left Front Turn Signal Circuit
B3949 Right Front Turn Signal Circuit
B3950 Left Rear Turn Signal Circuit
B3951 Right Rear Turn Signal Circuit
B3976 Unconfigured Transponder
C0000 Vehicle Speed Information Circuit
C0035 Left Front Wheel Speed Sensor Circuit
C0040 Right Front Wheel Speed Sensor Circuit
C0045 Left Rear Wheel Speed Sensor Circuit
C0050 Right Rear Wheel Speed Sensor Circuit
C0110 Pump Motor Circuit
C0131 ABS Pressure Circuit
C0161 ABS/TCS Brake Switch Circuit Signal Malfunction
C0176 System Thermal Error
C0186 Lateral Accelerometer
C0196 Yaw Rate Circuit
C0201 Antilock Brake System (ABS) Enable Relay Contact Circuit
C0252 Steering Wheel Position Sensor
C0267 Low Brake Fluid Indicated
C0277 Brake Pedal Position Sensor Circuit
C0278 Brake Pedal Position Sensor
C0280 Stability System Active Too Long
C0292 VSES Combination Sensor Circuits
C0299 Brake Booster Performance
C0460 Steering Position Signal
C0475 Electric Steering Motor Circuit
C0545 Steering Wheel Torque Input Sensor
C0550 Electronic Control Unit (ECU) Performance
C0551 Option Configuration Error
C0561 System Disabled Information Stored
C0569 System Configuration Error
C056E ECU Software Performance
C0750 Left Front Low Tire Pressure Sensor
C0755 Right Front Low Tire Pressure Sensor
C0760 Left Rear Low Tire Pressure Sensor
C0765 Right Rear Low Tire Pressure Sensor
C0775 Low Tire Pressure System Sensors Not Learned
C0800 Device Power Circuit Voltage
C0845 Device Ignition 1 Circuit
C0870 Device Voltage Reference Output 1 Circuit Voltage
C1100 Brake Booster Vacuum Sensor
Old Apr 4, 2008 | 04:30 PM
ChevyMgr's Avatar
List of P trouble codes (part 1):
DTC Description
P0010 Intake Camshaft Position (CMP) Actuator Solenoid Control Circuit
P0011 Intake Camshaft Position (CMP) System Performance
P0013 Exhaust Camshaft Position (CMP) Actuator Solenoid Control Circuit
P0014 Exhaust Camshaft Position (CMP) System Performance
P0016 Crankshaft Position (CKP)-Camshaft Position (CMP) Correlation
P0017 Crankshaft Position (CKP)-Exhaust Camshaft Position (CMP) Correlation
P0030 HO2S Heater Control Circuit Sensor 1
P0031 HO2S Heater Control Circuit Low Voltage Sensor 1
P0032 HO2S Heater Control Circuit High Voltage Sensor 1
P0033 Turbocharger Bypass Valve Solenoid Control Circuit
P0034 Turbocharger Bypass Valve Solenoid Control Circuit Low Voltage
P0035 Turbocharger Bypass Valve Solenoid Control Circuit High Voltage
P0036 HO2S Heater Control Circuit Sensor 2
P0037 HO2S Heater Control Circuit Low Voltage Sensor 2
P0038 HO2S Heater Control Circuit High Voltage Sensor 2
P0053 HO2S Heater Resistance Sensor 1
P0054 HO2S Heater Resistance Sensor 2
P0068 Throttle Body Airflow Performance
P0087 Fuel Rail Pressure (FRP) Too Low
P0088 Fuel Rail Pressure (FRP) Too High
P0089 Fuel Rail Pressure (FRP) Regulator Performance
P0090 Fuel Pressure Regulator Control Circuit
P0091 Fuel Pressure Regulator Solenoid 1 Control Circuit Low Voltage
P0092 Fuel Pressure Regulator Solenoid 1 Control Circuit High Voltage
P0096 Intake Air Temperature (IAT) Sensor 2 Performance
P0097 Intake Air Temperature (IAT) Sensor 2 Circuit Low Voltage
P0098 Intake Air Temperature (IAT) Sensor 2 Circuit High Voltage
P0099 Intake Air Temperature (IAT) Sensor 2 Circuit Intermittent
P0100 Mass Air Flow (MAF) Sensor Circuit
P0101 Mass Air Flow (MAF) Sensor Performance
P0102 Mass Air Flow (MAF) Sensor Circuit Low Frequency
P0103 Mass Air Flow (MAF) Sensor Circuit High Frequency
P0106 Manifold Absolute Pressure (MAP) Sensor Performance
P0107 Manifold Absolute Pressure (MAP) Sensor Circuit Low Voltage
P0108 Manifold Absolute Pressure (MAP) Sensor Circuit High Voltage
P0112 Intake Air Temperature (IAT) Sensor Circuit Low Voltage
P0113 Intake Air Temperature (IAT) Sensor Circuit High Voltage
P0114 Intake Air Temperature (IAT) Sensor Circuit Intermittent
P0116 Engine Coolant Temperature (ECT) Sensor Performance
P0117 Engine Coolant Temperature (ECT) Sensor Circuit Low Voltage
P0118 Engine Coolant Temperature (ECT) Sensor Circuit High Voltage
P0119 Engine Coolant Temperature (ECT) Sensor Circuit Intermittent
P0120 Throttle Position (TP) Sensor Circuit
P0121 Throttle Position (TP) Sensor 1 Performance
P0122 Throttle Position (TP) Sensor 1 Circuit Low Voltage
P0123 Throttle Position (TP) Sensor 1 Circuit High Voltage
P0128 Engine Coolant Temperature (ECT) Below Thermostat Regulating Temperature
P0130 HO2S Circuit Closed Loop (CL) Performance Sensor 1
P0131 HO2S Circuit Low Voltage Sensor 1
P0132 HO2S Circuit High Voltage Sensor 1
P0133 HO2S Slow Response Sensor 1
P0134 HO2S Circuit Insufficient Activity Sensor 1
P0135 HO2S Heater Performance Sensor 1
P0137 HO2S Circuit Low Voltage Sensor 2
P0138 HO2S Circuit High Voltage Sensor 2
P013A HO2S Slow Response Rich to Lean Sensor 2
P013B HO2S Slow Response Lean to Rich Sensor 2
P013E HO2S Delayed Response Rich to Lean Sensor 2
P013F HO2S Delayed Response Lean to Rich Sensor 2
P0140 HO2S Circuit Insufficient Activity Sensor 2
P0141 HO2S Heater Performance Sensor 2
P0171 Fuel Trim System Lean
P0172 Fuel Trim System Rich
P0191 Fuel Rail Pressure (FRP) Sensor Performance
P0192 Fuel Rail Pressure (FRP) Sensor Circuit Low Voltage
P0193 Fuel Rail Pressure (FRP) Sensor Circuit High Voltage
P0201 Injector 1 Control Circuit
P0202 Injector 2 Control Circuit
P0203 Injector 3 Control Circuit
P0204 Injector 4 Control Circuit
P0218 Transmission Fluid Overtemperature
P0220 Throttle Position (TP) Sensor 2 Circuit
P0221 Throttle Position (TP) Sensor 2 Performance
P0222 Throttle Position (TP) Sensor 2 Circuit Low Voltage
P0223 Throttle Position (TP) Sensor 2 Circuit High Voltage
P0230 Fuel Pump Relay Control Circuit
P0234 Turbocharger Engine Overboost
P0236 Turbocharger Boost System Performance
P0237 Turbocharger Boost Sensor Circuit Low Voltage
P0238 Turbocharger Boost Sensor Circuit High Voltage
P0243 Turbocharger Wastegate Solenoid Control Circuit
P0245 Turbocharger Wastegate Solenoid Control Circuit Low Voltage
P0246 Turbocharger Wastegate Solenoid Control Circuit High Voltage
P0261 Injector 1 Control Circuit Low Voltage
P0262 Injector 1 Control Circuit High Voltage
P0264 Injector 2 Control Circuit Low Voltage
P0265 Injector 2 Control Circuit High Voltage
P0267 Injector 3 Control Circuit Low Voltage
P0268 Injector 3 Control Circuit High Voltage
P0270 Injector 4 Control Circuit Low Voltage
P0271 Injector 4 Control Circuit High Voltage
P0299 Turbocharger Engine Underboost
P029D Injector 1 Leak
P02A1 Injector 2 Leak
P02A5 Injector 3 Leak
P02A9 Injector 4 Leak
P0300 Engine Misfire Detected
P0301 Cylinder 1 Misfire Detected
P0302 Cylinder 2 Misfire Detected
P0303 Cylinder 3 Misfire Detected
P0304 Cylinder 4 Misfire Detected
P0315 Crankshaft Position (CKP) System Variation Not Learned
P0324 Knock Sensor (KS) Performance
P0325 Knock Sensor (KS) Circuit
P0326 Knock Sensor (KS) Performance
P0327 Knock Sensor (KS) Circuit Low Voltage
P0328 Knock Sensor (KS) Circuit High Voltage
P0331 Knock Sensor (KS) 2 Performance
P0332 Knock Sensor (KS) 2 Circuit Low Voltage
P0333 Knock Sensor (KS) 2 Circuit High Voltage
P0335 Crankshaft Position (CKP) Sensor Circuit
P0336 Crankshaft Position (CKP) Sensor Performance
P0338 Crankshaft Position (CKP) Sensor Circuit High Duty Cycle
P0340 Intake Camshaft Position (CMP) Sensor Circuit
P0341 Intake Camshaft Position (CMP) Sensor Performance
P0342 Intake Camshaft Position (CMP) Sensor Circuit Low Voltage
P0343 Intake Camshaft Position (CMP) Sensor Circuit High Voltage
P0351 Ignition Coil 1 Control Circuit
P0352 Ignition Coil 2 Control Circuit
P0353 Ignition Coil 3 Control Circuit
P0354 Ignition Coil 4 Control Circuit
P0365 Exhaust Camshaft Position (CMP) Sensor Circuit
P0366 Exhaust Camshaft Position (CMP) Sensor Performance
P0367 Exhaust Camshaft Position (CMP) Sensor Circuit Low Voltage
P0368 Exhaust Camshaft Position (CMP) Sensor Circuit High Voltage
P0420 Catalyst System Low Efficiency
P0442 Evaporative Emissions (EVAP) System Small Leak Detected
P0443 Evaporative Emission (EVAP) Purge Solenoid Control Circuit
P0446 Evaporative Emissions (EVAP) Vent System Performance
P0449 Evaporative Emission (EVAP) Vent Solenoid Control Circuit
P0450 Fuel Tank Pressure (FTP) Sensor Circuit
P0451 Fuel Tank Pressure (FTP) Sensor Performance
P0452 Fuel Tank Pressure (FTP) Sensor Circuit Low Voltage
P0453 Fuel Tank Pressure (FTP) Sensor Circuit High Voltage
P0454 Fuel Tank Pressure (FTP) Sensor Circuit Intermittent
P0455 Evaporative Emission (EVAP) System Large Leak
P0458 Evaporative Emission (EVAP) Purge Solenoid Control Circuit Low Voltage
P0459 Evaporative Emission (EVAP) Purge Solenoid Control Circuit High Voltage
P0461 Fuel Level Sensor Circuit Performance
P0462 Fuel Level Sensor Circuit Low Voltage
P0463 Fuel Level Sensor Circuit High Voltage
P0464 Fuel Level Sensor 1 Circuit Intermittent
P0480 Cooling Fan Speed Output Circuit
Cooling Fan Relay Control Circuit
P0496 Evaporative Emission (EVAP) System Flow During Non-Purge
P0497 Evaporative Emission System Low Purge Flow
P0498 Evaporative Emission (EVAP) Vent Solenoid Control Circuit Low Voltage
P0499 Evaporative Emission (EVAP) Vent Solenoid Control Circuit High Voltage
P0501 Vehicle Speed Sensor (VSS) Performance
P0502 Vehicle Speed Sensor (VSS) Circuit Low Voltage
P0503 Vehicle Speed Sensor (VSS) Circuit Intermittent
P0506 Idle Speed Low
P0507 Idle Speed High
P050A Cold Start Idle Air Control System Performance
P0520 Engine Oil Pressure (EOP) Sensor Circuit
P0532 Air Conditioning Pressure Sensor Circuit Low Voltage
P0533 Air Conditioning Pressure Sensor Circuit High Voltage
P0562 System Voltage Low
P0563 System Voltage High
P0572 Brake Switch Circuit 1 Low Voltage
P0573 Brake Switch Circuit 1 High Voltage
P0575 Cruise Control Switch Signal Circuit
Old Apr 4, 2008 | 04:32 PM
ChevyMgr's Avatar
List of P trouble codes (part 2):
P0601 Control Module Read Only Memory (ROM)
Transmission Control Module (TCM) Read Only Memory (ROM)
P0602 Control Module Not Programmed
Transmission Control Module (TCM) Not Programmed
P0603 Control Module Long Term Memory Reset
Transmission Control Module (TCM) Long Term Memory Reset
P0604 Control Module Random Access Memory (RAM)
Transmission Control Module (TCM) Random Access Memory (RAM)
P0606 Control Module Internal Performance
P0607 Control Module Performance
P060D Control Module Accelerator Pedal Position (APP) System Performance
P0615 Starter Relay Control Circuit
P0621 Generator L-Teminal Circuit
P0622 Generator F-Terminal Circuit
P0627 Fuel Pump Relay Control Circuit
P0628 Fuel Pump Relay Control Circuit Low Voltage
P0629 Fuel Pump Relay Control Circuit High Voltage
P062B Control Module Fuel Injector Control Performance
P062F Control Module Long Term Memory Performance
Transmission Control Module (TCM) Long Term Memory Performance
P0638 Throttle Actuator Control (TAC) Command Performance
P0641 5-Volt Reference 1 Circuit
P0642 5-Volt Reference 1 Low Voltage
P0643 5-Volt Reference 1 High Voltage
P0645 Air Conditioning Clutch Relay Control Circuit
P064D Control Module HO2S 1 System Performance
P0650 Malfunction Indicator Lamp (MIL) Control Circuit
P0651 5-Volt Reference 2 Circuit
P0652 5-Volt Reference 2 Low Voltage
P0653 5-Volt Reference 2 High Voltage
P0685 Engine Controls Ignition Relay Control Circuit
P0686 Engine Controls Ignition Relay Control Circuit Low Voltage
P0687 Engine Controls Ignition Relay Control Circuit High Voltage
P0689 Engine Controls Ignition Relay Feedback Circuit Low Voltage
P0690 Engine Controls Ignition Relay Feedback Circuit High Voltage
P0691 Cooling Fan Speed Output Circuit Low Voltage
P0692 Cooling Fan Speed Output Circuit High Voltage
P0697 5-Volt Reference 3 Circuit
P0698 5-Volt Reference 3 Low Voltage
P0699 5-Volt Reference 3 High Voltage
P0700 Transmission Control Module (TCM) Requested MIL Illumination
P0703 Brake Switch Circuit 2
P0705 Transmission Range (TR) Switch Circuit
P0711 Transmission Fluid Temperature (TFT) Sensor Performance
P0712 Transmission Fluid Temperature (TFT) Sensor Circuit Low Voltage
P0713 Transmission Fluid Temperature (TFT) Sensor Circuit High Voltage
P0716 Input Speed Sensor Performance
P0717 Input Speed Sensor Circuit Low Voltage
P0722 Output Speed Sensor Circuit Low Voltage
P0723 Output Speed Sensor Circuit High Voltage
P0741 Torque Converter Clutch (TCC) System - Stuck Off
P0742 Torque Converter Clutch (TCC) System - Stuck On
P0751 1-2 Shift solenoid (SS) Valve Performance - No First or Fourth Gear
P0752 1-2 Shift solenoid (SS) Valve Performance - No Second or Third Gear
P0756 2-3 Shift Solenoid (SS) Valve Performance - No First or Second Gear
P0757 2-3 Shift Solenoid (SS) Valve Performance - No Third or Fourth Gear
P0806 Clutch Pedal Position (CPP) Sensor Circuit Performance
P0807 Clutch Pedal Position (CPP) Sensor Circuit Low Voltage
P0808 Clutch Pedal Position (CPP) Sensor Circuit High Voltage
P080A Clutch Pedal Position (CPP) Not Learned
P0842 Transmission Fluid Pressure (TFP) Sensor Circuit Low Voltage
P0843 Transmission Fluid Pressure (TFP) Sensor Circuit High Voltage
P0856 Traction Control Request Circuit
P0961 Line Pressure Control (PC) Solenoid System Performance
P0973 1-2 Shift Solenoid (SS) Control Circuit Low Voltage
P0974 1-2 Shift Solenoid (SS) Control Circuit High Voltage
P0976 2-3 Shift Solenoid (SS) Control Circuit Low Voltage
P0977 2-3 Shift Solenoid (SS) Control Circuit High Voltage
P1101 Intake Air Flow System Performance
P1133 HO2S Insufficient Switching Sensor 1
P1174 Fuel Trim Cylinder Balance
P1400 Cold Start Emission Reduction Control System
P1516 Throttle Actuator Control (TAC) Module Throttle Actuator Position Performance
P1551 Throttle Valve Rest Position Not Reached During Learn
P1629 Theft Deterrent Fuel Enable Signal Not Received
P1630 Theft Deterrent Learn Mode Active
P1631 Theft Deterrent Start Enable Signal Not Correct
P1632 Theft Deterrent Start Disable Signal Received
P167A Control Module HO2S 1 System Performance
P167D Control Module Ignition Coil Internal Circuit
P1682 Ignition 1 Switch Circuit 2
P1810 Transmission Fluid Pressure (TFP) Position Switch Circuit
P1811 Maximum Adapt and Long Shift
P1816 Transmission Fluid Pressure (TFP) Valve Position Switch Indicates Park/Neutral (P/N) with Drive Ratio
P1818 Transmission Fluid Pressure (TFP) Valve Position Switch Indicates Drive without Drive Ratio
P2088 Intake Camshaft Position (CMP) Actuator Solenoid Control Circuit Low Voltage
P2089 Intake Camshaft Position (CMP) Actuator Solenoid Control Circuit High Voltage
P2090 Exhaust Camshaft Position (CMP) Actuator Solenoid Control Circuit Low Voltage
P2091 Exhaust Camshaft Position (CMP) Actuator Solenoid Control Circuit High Voltage
P2096 Post Catalyst Fuel Trim System Low Limit Bank 1
P2097 Post Catalyst Fuel Trim System High Limit Bank 1
P2100 Throttle Actuator Control (TAC) Motor Control Circuit
P2101 Throttle Actuator Position Performance
P2105 Throttle Actuator Control (TAC) System Forced Engine Shutdown
P2119 Throttle Closed Position Performance
P2120 Accelerator Pedal Position (APP) Sensor 1 Circuit
P2122 Accelerator Pedal Position (APP) Sensor 1 Circuit Low Voltage
P2123 Accelerator Pedal Position (APP) Sensor 1 Circuit High Voltage
P2125 Accelerator Pedal Position (APP) Sensor 2 Circuit
P2127 Accelerator Pedal Position (APP) Sensor 2 Circuit Low Voltage
P2128 Accelerator Pedal Position (APP) Sensor 2 Circuit High Voltage
P2135 Throttle Position (TP) Sensor 1-2 Correlation
P2138 Accelerator Pedal Position (APP) Sensor 1-2 Correlation
P2146 Injector Positive Voltage Control Circuit Group 1
P2149 Injector Positive Voltage Control Circuit Group 2
P2152 Injector Positive Voltage Control Circuit Group 3
P2155 Injector Positive Voltage Control Circuit Group 4
P2176 Minimum Throttle Position Not Learned
P2177 Fuel Trim System Lean at Cruise or Accel
P2178 Fuel Trim System Rich at Cruise or Accel
P2187 Fuel Trim System Lean at Idle
P2188 Fuel Trim System Rich at Idle
P2195 HO2S Signal Biased Lean Sensor 1
P2196 HO2S Signal Biased Rich Sensor 1
P2199 Intake Air Temperature (IAT) Sensor 1-2 Correlation
P2227 Barometric Pressure (BARO) Sensor Performance
P2228 Barometric Pressure (BARO) Sensor Circuit Low Voltage
P2229 Barometric Pressure (BARO) Sensor Circuit High Voltage
P2232 HO2S Signal Circuit Shorted to Heater Circuit Sensor 2
P2237 HO2S Pumping Current Control Circuit Sensor 1
P2243 HO2S Reference Voltage Circuit Sensor 1
P2251 HO2S Low Reference Circuit Sensor 1
P2261 Turbocharger Bypass Valve Stuck Closed
P2270 HO2S Signal Stuck Lean Sensor 2
P2271 HO2S Signal Stuck Rich Sensor 2
P2297 HO2S Performance During Decel Fuel Cut-Off (DFCO) Sensor 1
P2300 Ignition Coil 1 Control Circuit Low Voltage
P2301 Ignition Coil 1 Control Circuit High Voltage
P2303 Ignition Coil 2 Control Circuit Low Voltage
P2304 Ignition Coil 2 Control Circuit High Voltage
P2306 Ignition Coil 3 Control Circuit Low Voltage
P2307 Ignition Coil 3 Control Circuit High Voltage
P2309 Ignition Coil 4 Control Circuit Low Voltage
P2310 Ignition Coil 4 Control Circuit High Voltage
P2534 Ignition 1 Switch Circuit Low Voltage
P2535 Ignition 1 Switch Circuit High Voltage
P2544 Transmission Torque Request Circuit
P2610 Control Module Ignition Off Timer Performance
P2626 HO2S Pumping Current Trim Circuit Sensor 1
P2763 Torque Converter Clutch (TCC) Pressure Control (PC) Solenoid Control Circuit High Voltage
P2764 Torque Converter Clutch (TCC) Pressure Control (PC) Solenoid Control Circuit Low Voltage
P2A00 HO2S Circuit Closed Loop (CL) Performance Sensor 1
U0001 High Speed CAN Communication Bus
U0073 Controller Area Network (CAN) Bus Communication
U1300 Class 2 Data Link Low
U1301 Class 2 Data Link High
U1305 Class 2 Data Link Low or High
U2103 Fewer Controllers On Bus Than Programmed
U2105 Lost Communications With Engine Control System
U2106 Lost Communications With Transmission Control System
U2107 Lost Communications With Body Control System
U2108 Lost Communications With ABS/TCS Control System
U2109 Lost Communications With Powertrain Multiple Control System
U2111 Lost Communications With Steering Control System
U2113 Lost Communications With Sensing and Diagnostic Module (SDM)
U2116 Lost Communications With Instrument Panel Cluster (IPC)
U2125 Lost Communication With Mobile Communications Control Systems
U2127 Lost Communications With Front HVAC
U2137 Lost Communications With Vehicle Theft Deterrent (VTD)
U2171 Lost Communications With DVD Player
U2172 Lost Communications With Digital Radio Receiver
023 Seat Belt Tension Sensor Circuit Out of Range
024 PPS Ignition 1 Voltage Performance
063 PPS Out of Calibration
064 Communication/ID Performance
065 Sensor Circuit Out of Range
Old Apr 4, 2008 | 04:34 PM
karen1953's Avatar
Wow Thanks!
Old Apr 4, 2008 | 04:44 PM
d-man's Avatar
THIS WILL BE VERY HELPFULL, THANKS FOR SHARING THE INFO AND TAKIN' THE TIME TO POST
Old Apr 4, 2008 | 04:52 PM
HipHotRod's Avatar
He started typing that post 2 weeks ago!......Man you talkin about goin to the wall for the HHR Homies!
Old Apr 4, 2008 | 05:03 PM
ChevyMgr's Avatar
Copy and Paste, it's the only way to get things done fast!
I tried to get the files down to a size acceptable by the site so I could post as attachments, but I couldn't no matter what format I used.
Old Apr 4, 2008 | 05:06 PM
Snoopy's Avatar
Hey ChevyMgr.....
I suggest that YOU SUGGEST TO THE MOD's to make THESE a STICKEY !!!!
Old Apr 4, 2008 | 06:12 PM
bigallis1's Avatar
Thank you ChevyMgr. We are lucky to have you supporting us.
Old Apr 4, 2008 | 07:37 PM
GCarp's Avatar
