List of Diagnostic Trouble Codes for 2008-2010 HHR
List of B & C trouble codes for anyone wondering what they mean.
DTC Description B0012 Driver Frontal Deployment Loop Stage 1 B0013 Driver Frontal Deployment Loop Stage 2 B0015 Left Front Seat Belt Pretensioner Deployment Loop B0016 Left Roof Rail Deployment Loop B0019 Passenger Frontal Deployment Loop Stage 1 B0020 Passenger Frontal Deployment Loop Stage 2 B0022 Right Front Seat Belt Pretensioner Deployment Loop B0023 Right Roof Rail Deployment Loop B0052 Deployment Commanded B0053 Deployment Commanded with Loop DTCs Present B0081 Passenger Presence System B0083 Front End Sensor 1 B0085 Left Front Side Impact Sensor B0086 Right Front Side Impact Sensor B0090 Rollover Sensor B0158 Ambient Air Temperature Sensor Circuit B0283 Electric Rear Defrost Circuit B0685 Security System Indicator Circuit Short to Battery B1000 Electronic Control Unit (ECU) Performance B1001 Option Configuration Error B1008 Calibration Data Not Programmed B1009 EEPROM Checksum Mismatch B1011 System Disabled Information Stored Invalid Serial Data Received B1019 System Configuration Error B1025 Left Front Audio Output Circuit B1035 Right Front Audio Output Circuit B1045 Left Rear Audio Output Circuit B1055 Right Rear Audio Output Circuit B1259 Antenna Ground Circuit B1287 External Amp Control B1325 Device Power 1 Circuit B1370 Device Ignition 1 Circuit B1380 Device Ignition ACCESSORY Circuit B1424 Device Voltage Low B1441 Device Ignition OFF, RUN, and CRANK Circuit B1480 Battery Rundown Protection Circuit B1516 Battery Current Sensor Performance Signal Invalid B1517 Battery 1 Voltage B2455 Cellular Phone Microphone Circuit Malfunction B2470 Cellular Phone Antenna Circuit Malfunction B2476 Cellular Phone Select Service Switch Malfunction B2482 Cellular Phone Select Switch Range/Performance B2483 GPS Sensor Circuit Low B2484 GPS Sensor Circuit Open B250D Left Rear Door Unlatch Low Control Circuit B250E Right Rear Door Unlatch Low Control Circuit B2530 Front Fog Lamps Control Circuit B2555 Passenger Compartment Lamp Control Circuit B2580 Headlamp High Beam Control Circuit B2625 Display Dimming Pulse Width Modulation (PWM) Output Circuit B2645 Ambient Light Sensor Circuit B2705 Gearshift Unlock Circuit B2750 Horn Relay Output B3006 Hood Ajar Circuit B3031 Security System Controller In Learn Mode B3055 No Transponder Modulation or No Transponder B3060 Unprogrammed Transponder Identification Code Received B3105 Keyless Entry System Key Fobs Not Programmed B3109 Keyless Transmitter Low Battery B3110 Keyless Entry Transmitter 2 Low Battery B3111 Keyless Entry Transmitter 3 Low Battery B3112 Keyless Entry Transmitter 4 Battery B312A Door Latch Actuators Enable Relay Control Circuit B3265 Trunk Relay Output B3715 Front Wiper Relay Drive Circuit B3716 Front Wiper Relay Drive Circuit Range/Performance B3717 Front Wiper Relay Drive Circuit Low B3718 Front Wiper Relay Drive Circuit High B3719 Front Wiper Relay Drive Circuit Open B3794 Cruise Control Function Request Circuit B3903 Stop Lamp Relay Circuit B3935 Transponder Authentication Error B3948 Left Front Turn Signal Circuit B3949 Right Front Turn Signal Circuit B3950 Left Rear Turn Signal Circuit B3951 Right Rear Turn Signal Circuit B3976 Unconfigured Transponder C0000 Vehicle Speed Information Circuit C0035 Left Front Wheel Speed Sensor Circuit C0040 Right Front Wheel Speed Sensor Circuit C0045 Left Rear Wheel Speed Sensor Circuit C0050 Right Rear Wheel Speed Sensor Circuit C0110 Pump Motor Circuit C0131 ABS Pressure Circuit C0161 ABS/TCS Brake Switch Circuit Signal Malfunction C0176 System Thermal Error C0186 Lateral Accelerometer C0196 Yaw Rate Circuit C0201 Antilock Brake System (ABS) Enable Relay Contact Circuit C0252 Steering Wheel Position Sensor C0267 Low Brake Fluid Indicated C0277 Brake Pedal Position Sensor Circuit C0278 Brake Pedal Position Sensor C0280 Stability System Active Too Long C0292 VSES Combination Sensor Circuits C0299 Brake Booster Performance C0460 Steering Position Signal C0475 Electric Steering Motor Circuit C0545 Steering Wheel Torque Input Sensor C0550 Electronic Control Unit (ECU) Performance C0551 Option Configuration Error C0561 System Disabled Information Stored C0569 System Configuration Error C056E ECU Software Performance C0750 Left Front Low Tire Pressure Sensor C0755 Right Front Low Tire Pressure Sensor C0760 Left Rear Low Tire Pressure Sensor C0765 Right Rear Low Tire Pressure Sensor C0775 Low Tire Pressure System Sensors Not Learned C0800 Device Power Circuit Voltage C0845 Device Ignition 1 Circuit C0870 Device Voltage Reference Output 1 Circuit Voltage C1100 Brake Booster Vacuum Sensor |
List of P trouble codes (part 1):
DTC Description P0010 Intake Camshaft Position (CMP) Actuator Solenoid Control Circuit P0011 Intake Camshaft Position (CMP) System Performance P0013 Exhaust Camshaft Position (CMP) Actuator Solenoid Control Circuit P0014 Exhaust Camshaft Position (CMP) System Performance P0016 Crankshaft Position (CKP)-Camshaft Position (CMP) Correlation P0017 Crankshaft Position (CKP)-Exhaust Camshaft Position (CMP) Correlation P0030 HO2S Heater Control Circuit Sensor 1 P0031 HO2S Heater Control Circuit Low Voltage Sensor 1 P0032 HO2S Heater Control Circuit High Voltage Sensor 1 P0033 Turbocharger Bypass Valve Solenoid Control Circuit P0034 Turbocharger Bypass Valve Solenoid Control Circuit Low Voltage P0035 Turbocharger Bypass Valve Solenoid Control Circuit High Voltage P0036 HO2S Heater Control Circuit Sensor 2 P0037 HO2S Heater Control Circuit Low Voltage Sensor 2 P0038 HO2S Heater Control Circuit High Voltage Sensor 2 P0053 HO2S Heater Resistance Sensor 1 P0054 HO2S Heater Resistance Sensor 2 P0068 Throttle Body Airflow Performance P0087 Fuel Rail Pressure (FRP) Too Low P0088 Fuel Rail Pressure (FRP) Too High P0089 Fuel Rail Pressure (FRP) Regulator Performance P0090 Fuel Pressure Regulator Control Circuit P0091 Fuel Pressure Regulator Solenoid 1 Control Circuit Low Voltage P0092 Fuel Pressure Regulator Solenoid 1 Control Circuit High Voltage P0096 Intake Air Temperature (IAT) Sensor 2 Performance P0097 Intake Air Temperature (IAT) Sensor 2 Circuit Low Voltage P0098 Intake Air Temperature (IAT) Sensor 2 Circuit High Voltage P0099 Intake Air Temperature (IAT) Sensor 2 Circuit Intermittent P0100 Mass Air Flow (MAF) Sensor Circuit P0101 Mass Air Flow (MAF) Sensor Performance P0102 Mass Air Flow (MAF) Sensor Circuit Low Frequency P0103 Mass Air Flow (MAF) Sensor Circuit High Frequency P0106 Manifold Absolute Pressure (MAP) Sensor Performance P0107 Manifold Absolute Pressure (MAP) Sensor Circuit Low Voltage P0108 Manifold Absolute Pressure (MAP) Sensor Circuit High Voltage P0112 Intake Air Temperature (IAT) Sensor Circuit Low Voltage P0113 Intake Air Temperature (IAT) Sensor Circuit High Voltage P0114 Intake Air Temperature (IAT) Sensor Circuit Intermittent P0116 Engine Coolant Temperature (ECT) Sensor Performance P0117 Engine Coolant Temperature (ECT) Sensor Circuit Low Voltage P0118 Engine Coolant Temperature (ECT) Sensor Circuit High Voltage P0119 Engine Coolant Temperature (ECT) Sensor Circuit Intermittent P0120 Throttle Position (TP) Sensor Circuit P0121 Throttle Position (TP) Sensor 1 Performance P0122 Throttle Position (TP) Sensor 1 Circuit Low Voltage P0123 Throttle Position (TP) Sensor 1 Circuit High Voltage P0128 Engine Coolant Temperature (ECT) Below Thermostat Regulating Temperature P0130 HO2S Circuit Closed Loop (CL) Performance Sensor 1 P0131 HO2S Circuit Low Voltage Sensor 1 P0132 HO2S Circuit High Voltage Sensor 1 P0133 HO2S Slow Response Sensor 1 P0134 HO2S Circuit Insufficient Activity Sensor 1 P0135 HO2S Heater Performance Sensor 1 P0137 HO2S Circuit Low Voltage Sensor 2 P0138 HO2S Circuit High Voltage Sensor 2 P013A HO2S Slow Response Rich to Lean Sensor 2 P013B HO2S Slow Response Lean to Rich Sensor 2 P013E HO2S Delayed Response Rich to Lean Sensor 2 P013F HO2S Delayed Response Lean to Rich Sensor 2 P0140 HO2S Circuit Insufficient Activity Sensor 2 P0141 HO2S Heater Performance Sensor 2 P0171 Fuel Trim System Lean P0172 Fuel Trim System Rich P0191 Fuel Rail Pressure (FRP) Sensor Performance P0192 Fuel Rail Pressure (FRP) Sensor Circuit Low Voltage P0193 Fuel Rail Pressure (FRP) Sensor Circuit High Voltage P0201 Injector 1 Control Circuit P0202 Injector 2 Control Circuit P0203 Injector 3 Control Circuit P0204 Injector 4 Control Circuit P0218 Transmission Fluid Overtemperature P0220 Throttle Position (TP) Sensor 2 Circuit P0221 Throttle Position (TP) Sensor 2 Performance P0222 Throttle Position (TP) Sensor 2 Circuit Low Voltage P0223 Throttle Position (TP) Sensor 2 Circuit High Voltage P0230 Fuel Pump Relay Control Circuit P0234 Turbocharger Engine Overboost P0236 Turbocharger Boost System Performance P0237 Turbocharger Boost Sensor Circuit Low Voltage P0238 Turbocharger Boost Sensor Circuit High Voltage P0243 Turbocharger Wastegate Solenoid Control Circuit P0245 Turbocharger Wastegate Solenoid Control Circuit Low Voltage P0246 Turbocharger Wastegate Solenoid Control Circuit High Voltage P0261 Injector 1 Control Circuit Low Voltage P0262 Injector 1 Control Circuit High Voltage P0264 Injector 2 Control Circuit Low Voltage P0265 Injector 2 Control Circuit High Voltage P0267 Injector 3 Control Circuit Low Voltage P0268 Injector 3 Control Circuit High Voltage P0270 Injector 4 Control Circuit Low Voltage P0271 Injector 4 Control Circuit High Voltage P0299 Turbocharger Engine Underboost P029D Injector 1 Leak P02A1 Injector 2 Leak P02A5 Injector 3 Leak P02A9 Injector 4 Leak P0300 Engine Misfire Detected P0301 Cylinder 1 Misfire Detected P0302 Cylinder 2 Misfire Detected P0303 Cylinder 3 Misfire Detected P0304 Cylinder 4 Misfire Detected P0315 Crankshaft Position (CKP) System Variation Not Learned P0324 Knock Sensor (KS) Performance P0325 Knock Sensor (KS) Circuit P0326 Knock Sensor (KS) Performance P0327 Knock Sensor (KS) Circuit Low Voltage P0328 Knock Sensor (KS) Circuit High Voltage P0331 Knock Sensor (KS) 2 Performance P0332 Knock Sensor (KS) 2 Circuit Low Voltage P0333 Knock Sensor (KS) 2 Circuit High Voltage P0335 Crankshaft Position (CKP) Sensor Circuit P0336 Crankshaft Position (CKP) Sensor Performance P0338 Crankshaft Position (CKP) Sensor Circuit High Duty Cycle P0340 Intake Camshaft Position (CMP) Sensor Circuit P0341 Intake Camshaft Position (CMP) Sensor Performance P0342 Intake Camshaft Position (CMP) Sensor Circuit Low Voltage P0343 Intake Camshaft Position (CMP) Sensor Circuit High Voltage P0351 Ignition Coil 1 Control Circuit P0352 Ignition Coil 2 Control Circuit P0353 Ignition Coil 3 Control Circuit P0354 Ignition Coil 4 Control Circuit P0365 Exhaust Camshaft Position (CMP) Sensor Circuit P0366 Exhaust Camshaft Position (CMP) Sensor Performance P0367 Exhaust Camshaft Position (CMP) Sensor Circuit Low Voltage P0368 Exhaust Camshaft Position (CMP) Sensor Circuit High Voltage P0420 Catalyst System Low Efficiency P0442 Evaporative Emissions (EVAP) System Small Leak Detected P0443 Evaporative Emission (EVAP) Purge Solenoid Control Circuit P0446 Evaporative Emissions (EVAP) Vent System Performance P0449 Evaporative Emission (EVAP) Vent Solenoid Control Circuit P0450 Fuel Tank Pressure (FTP) Sensor Circuit P0451 Fuel Tank Pressure (FTP) Sensor Performance P0452 Fuel Tank Pressure (FTP) Sensor Circuit Low Voltage P0453 Fuel Tank Pressure (FTP) Sensor Circuit High Voltage P0454 Fuel Tank Pressure (FTP) Sensor Circuit Intermittent P0455 Evaporative Emission (EVAP) System Large Leak P0458 Evaporative Emission (EVAP) Purge Solenoid Control Circuit Low Voltage P0459 Evaporative Emission (EVAP) Purge Solenoid Control Circuit High Voltage P0461 Fuel Level Sensor Circuit Performance P0462 Fuel Level Sensor Circuit Low Voltage P0463 Fuel Level Sensor Circuit High Voltage P0464 Fuel Level Sensor 1 Circuit Intermittent P0480 Cooling Fan Speed Output Circuit Cooling Fan Relay Control Circuit P0496 Evaporative Emission (EVAP) System Flow During Non-Purge P0497 Evaporative Emission System Low Purge Flow P0498 Evaporative Emission (EVAP) Vent Solenoid Control Circuit Low Voltage P0499 Evaporative Emission (EVAP) Vent Solenoid Control Circuit High Voltage P0501 Vehicle Speed Sensor (VSS) Performance P0502 Vehicle Speed Sensor (VSS) Circuit Low Voltage P0503 Vehicle Speed Sensor (VSS) Circuit Intermittent P0506 Idle Speed Low P0507 Idle Speed High P050A Cold Start Idle Air Control System Performance P0520 Engine Oil Pressure (EOP) Sensor Circuit P0532 Air Conditioning Pressure Sensor Circuit Low Voltage P0533 Air Conditioning Pressure Sensor Circuit High Voltage P0562 System Voltage Low P0563 System Voltage High P0572 Brake Switch Circuit 1 Low Voltage P0573 Brake Switch Circuit 1 High Voltage P0575 Cruise Control Switch Signal Circuit |
List of P trouble codes (part 2):
P0601 Control Module Read Only Memory (ROM) Transmission Control Module (TCM) Read Only Memory (ROM) P0602 Control Module Not Programmed Transmission Control Module (TCM) Not Programmed P0603 Control Module Long Term Memory Reset Transmission Control Module (TCM) Long Term Memory Reset P0604 Control Module Random Access Memory (RAM) Transmission Control Module (TCM) Random Access Memory (RAM) P0606 Control Module Internal Performance P0607 Control Module Performance P060D Control Module Accelerator Pedal Position (APP) System Performance P0615 Starter Relay Control Circuit P0621 Generator L-Teminal Circuit P0622 Generator F-Terminal Circuit P0627 Fuel Pump Relay Control Circuit P0628 Fuel Pump Relay Control Circuit Low Voltage P0629 Fuel Pump Relay Control Circuit High Voltage P062B Control Module Fuel Injector Control Performance P062F Control Module Long Term Memory Performance Transmission Control Module (TCM) Long Term Memory Performance P0638 Throttle Actuator Control (TAC) Command Performance P0641 5-Volt Reference 1 Circuit P0642 5-Volt Reference 1 Low Voltage P0643 5-Volt Reference 1 High Voltage P0645 Air Conditioning Clutch Relay Control Circuit P064D Control Module HO2S 1 System Performance P0650 Malfunction Indicator Lamp (MIL) Control Circuit P0651 5-Volt Reference 2 Circuit P0652 5-Volt Reference 2 Low Voltage P0653 5-Volt Reference 2 High Voltage P0685 Engine Controls Ignition Relay Control Circuit P0686 Engine Controls Ignition Relay Control Circuit Low Voltage P0687 Engine Controls Ignition Relay Control Circuit High Voltage P0689 Engine Controls Ignition Relay Feedback Circuit Low Voltage P0690 Engine Controls Ignition Relay Feedback Circuit High Voltage P0691 Cooling Fan Speed Output Circuit Low Voltage P0692 Cooling Fan Speed Output Circuit High Voltage P0697 5-Volt Reference 3 Circuit P0698 5-Volt Reference 3 Low Voltage P0699 5-Volt Reference 3 High Voltage P0700 Transmission Control Module (TCM) Requested MIL Illumination P0703 Brake Switch Circuit 2 P0705 Transmission Range (TR) Switch Circuit P0711 Transmission Fluid Temperature (TFT) Sensor Performance P0712 Transmission Fluid Temperature (TFT) Sensor Circuit Low Voltage P0713 Transmission Fluid Temperature (TFT) Sensor Circuit High Voltage P0716 Input Speed Sensor Performance P0717 Input Speed Sensor Circuit Low Voltage P0722 Output Speed Sensor Circuit Low Voltage P0723 Output Speed Sensor Circuit High Voltage P0741 Torque Converter Clutch (TCC) System - Stuck Off P0742 Torque Converter Clutch (TCC) System - Stuck On P0751 1-2 Shift solenoid (SS) Valve Performance - No First or Fourth Gear P0752 1-2 Shift solenoid (SS) Valve Performance - No Second or Third Gear P0756 2-3 Shift Solenoid (SS) Valve Performance - No First or Second Gear P0757 2-3 Shift Solenoid (SS) Valve Performance - No Third or Fourth Gear P0806 Clutch Pedal Position (CPP) Sensor Circuit Performance P0807 Clutch Pedal Position (CPP) Sensor Circuit Low Voltage P0808 Clutch Pedal Position (CPP) Sensor Circuit High Voltage P080A Clutch Pedal Position (CPP) Not Learned P0842 Transmission Fluid Pressure (TFP) Sensor Circuit Low Voltage P0843 Transmission Fluid Pressure (TFP) Sensor Circuit High Voltage P0856 Traction Control Request Circuit P0961 Line Pressure Control (PC) Solenoid System Performance P0973 1-2 Shift Solenoid (SS) Control Circuit Low Voltage P0974 1-2 Shift Solenoid (SS) Control Circuit High Voltage P0976 2-3 Shift Solenoid (SS) Control Circuit Low Voltage P0977 2-3 Shift Solenoid (SS) Control Circuit High Voltage P1101 Intake Air Flow System Performance P1133 HO2S Insufficient Switching Sensor 1 P1174 Fuel Trim Cylinder Balance P1400 Cold Start Emission Reduction Control System P1516 Throttle Actuator Control (TAC) Module Throttle Actuator Position Performance P1551 Throttle Valve Rest Position Not Reached During Learn P1629 Theft Deterrent Fuel Enable Signal Not Received P1630 Theft Deterrent Learn Mode Active P1631 Theft Deterrent Start Enable Signal Not Correct P1632 Theft Deterrent Start Disable Signal Received P167A Control Module HO2S 1 System Performance P167D Control Module Ignition Coil Internal Circuit P1682 Ignition 1 Switch Circuit 2 P1810 Transmission Fluid Pressure (TFP) Position Switch Circuit P1811 Maximum Adapt and Long Shift P1816 Transmission Fluid Pressure (TFP) Valve Position Switch Indicates Park/Neutral (P/N) with Drive Ratio P1818 Transmission Fluid Pressure (TFP) Valve Position Switch Indicates Drive without Drive Ratio P2088 Intake Camshaft Position (CMP) Actuator Solenoid Control Circuit Low Voltage P2089 Intake Camshaft Position (CMP) Actuator Solenoid Control Circuit High Voltage P2090 Exhaust Camshaft Position (CMP) Actuator Solenoid Control Circuit Low Voltage P2091 Exhaust Camshaft Position (CMP) Actuator Solenoid Control Circuit High Voltage P2096 Post Catalyst Fuel Trim System Low Limit Bank 1 P2097 Post Catalyst Fuel Trim System High Limit Bank 1 P2100 Throttle Actuator Control (TAC) Motor Control Circuit P2101 Throttle Actuator Position Performance P2105 Throttle Actuator Control (TAC) System Forced Engine Shutdown P2119 Throttle Closed Position Performance P2120 Accelerator Pedal Position (APP) Sensor 1 Circuit P2122 Accelerator Pedal Position (APP) Sensor 1 Circuit Low Voltage P2123 Accelerator Pedal Position (APP) Sensor 1 Circuit High Voltage P2125 Accelerator Pedal Position (APP) Sensor 2 Circuit P2127 Accelerator Pedal Position (APP) Sensor 2 Circuit Low Voltage P2128 Accelerator Pedal Position (APP) Sensor 2 Circuit High Voltage P2135 Throttle Position (TP) Sensor 1-2 Correlation P2138 Accelerator Pedal Position (APP) Sensor 1-2 Correlation P2146 Injector Positive Voltage Control Circuit Group 1 P2149 Injector Positive Voltage Control Circuit Group 2 P2152 Injector Positive Voltage Control Circuit Group 3 P2155 Injector Positive Voltage Control Circuit Group 4 P2176 Minimum Throttle Position Not Learned P2177 Fuel Trim System Lean at Cruise or Accel P2178 Fuel Trim System Rich at Cruise or Accel P2187 Fuel Trim System Lean at Idle P2188 Fuel Trim System Rich at Idle P2195 HO2S Signal Biased Lean Sensor 1 P2196 HO2S Signal Biased Rich Sensor 1 P2199 Intake Air Temperature (IAT) Sensor 1-2 Correlation P2227 Barometric Pressure (BARO) Sensor Performance P2228 Barometric Pressure (BARO) Sensor Circuit Low Voltage P2229 Barometric Pressure (BARO) Sensor Circuit High Voltage P2232 HO2S Signal Circuit Shorted to Heater Circuit Sensor 2 P2237 HO2S Pumping Current Control Circuit Sensor 1 P2243 HO2S Reference Voltage Circuit Sensor 1 P2251 HO2S Low Reference Circuit Sensor 1 P2261 Turbocharger Bypass Valve Stuck Closed P2270 HO2S Signal Stuck Lean Sensor 2 P2271 HO2S Signal Stuck Rich Sensor 2 P2297 HO2S Performance During Decel Fuel Cut-Off (DFCO) Sensor 1 P2300 Ignition Coil 1 Control Circuit Low Voltage P2301 Ignition Coil 1 Control Circuit High Voltage P2303 Ignition Coil 2 Control Circuit Low Voltage P2304 Ignition Coil 2 Control Circuit High Voltage P2306 Ignition Coil 3 Control Circuit Low Voltage P2307 Ignition Coil 3 Control Circuit High Voltage P2309 Ignition Coil 4 Control Circuit Low Voltage P2310 Ignition Coil 4 Control Circuit High Voltage P2534 Ignition 1 Switch Circuit Low Voltage P2535 Ignition 1 Switch Circuit High Voltage P2544 Transmission Torque Request Circuit P2610 Control Module Ignition Off Timer Performance P2626 HO2S Pumping Current Trim Circuit Sensor 1 P2763 Torque Converter Clutch (TCC) Pressure Control (PC) Solenoid Control Circuit High Voltage P2764 Torque Converter Clutch (TCC) Pressure Control (PC) Solenoid Control Circuit Low Voltage P2A00 HO2S Circuit Closed Loop (CL) Performance Sensor 1 U0001 High Speed CAN Communication Bus U0073 Controller Area Network (CAN) Bus Communication U1300 Class 2 Data Link Low U1301 Class 2 Data Link High U1305 Class 2 Data Link Low or High U2103 Fewer Controllers On Bus Than Programmed U2105 Lost Communications With Engine Control System U2106 Lost Communications With Transmission Control System U2107 Lost Communications With Body Control System U2108 Lost Communications With ABS/TCS Control System U2109 Lost Communications With Powertrain Multiple Control System U2111 Lost Communications With Steering Control System U2113 Lost Communications With Sensing and Diagnostic Module (SDM) U2116 Lost Communications With Instrument Panel Cluster (IPC) U2125 Lost Communication With Mobile Communications Control Systems U2127 Lost Communications With Front HVAC U2137 Lost Communications With Vehicle Theft Deterrent (VTD) U2171 Lost Communications With DVD Player U2172 Lost Communications With Digital Radio Receiver 023 Seat Belt Tension Sensor Circuit Out of Range 024 PPS Ignition 1 Voltage Performance 063 PPS Out of Calibration 064 Communication/ID Performance 065 Sensor Circuit Out of Range |
Wow Thanks!
:thumb: THIS WILL BE VERY HELPFULL, THANKS FOR SHARING THE INFO AND TAKIN' THE TIME TO POST
He started typing that post 2 weeks ago!......Man you talkin about goin to the wall for the HHR Homies!
(Post 252745)
I tried to get the files down to a size acceptable by the site so I could post as attachments, but I couldn't no matter what format I used. |
Hey ChevyMgr.....
I suggest that YOU SUGGEST TO THE MOD's to make THESE a STICKEY !!!!:thumb: |
Thank you ChevyMgr. We are lucky to have you supporting us.
:bow: :bow: :bow: :bow: :bow: :one: :bow: :bow: :bow: :bow: :bow:
| All times are GMT -5. The time now is 02:01 AM. |
