loud snap sound
I have a 2006 and really like it even though it does have some quirks. The radio will come on sometimes when I use my auto lock entry. I also at time will have a loud snap/pop sound when I trun the car on. My delearship has changed out every component of the radio front to back. If it could only happen to then when they have it. Has anyone had the same issue? How was it fixed?
I noticed some owners have had issues with the brakes. I just spent close to $500.00 to replace disk and routers, 38,000 miles. |
GM has a TSB for the radio problem. The BCM needs to be reprogrammed. No parts replaced. You may want to contact a competent dealer who knows this.
Originally Posted by JoeR
(Post 416661)
TSB is tech service bullitin.
BCM is body control modual ? Go to the Dealer and tell them to look for a TBS to reprogram the BCM if they don't Know about it tell them to look for it or go to a competent dealer who knows this. |
Originally Posted by oneton
(Post 416856)
Mine had the pop noise every once in a while enough to blow out your ear drums when you went to start the car. The flashing of the bcm didnt help. I had xm also and my station would reset back to channel 2 if i left it on a xm station when i shut off. Mine was the XM module itself. They replaced it and all was fine after.
