Manual Shifter
Old Jul 1, 2024 | 08:54 AM
tboxx7714's Avatar
Manual Shifters - Both Match
See photos below. In the photos with both, the shifter on the left came out of my son's HHR. The shifter on the right is from a junkyard Cobalt. They are identical including "GM>PA6 GF30<" stamped on the top and "9920010" stamped on the bottom.
I also checked and the shift cables ends fit correctly into the receiving clips. So, anyone in need of a manual shifter can check the junkyards for Cobalts as well. Still don't know why the part numbers are different, but if it works....
However, note the Suppl-No (Supplier Number?) is the same and both made in Germany.
Cobalt Shifter
HHR Shifter (with my home engineering repair)
HHR n the left, Cobalt on the right.
Old Jul 1, 2024 | 09:14 AM
Thanks for confirming the shifters are compatible.
Old Jul 1, 2024 | 09:55 AM
Is this an optical illusion? They look totally different to me. The mounting holes are different.
Old Jul 1, 2024 | 10:02 AM
Possibly the left unit has a more robust nylon arm at the shifter ball
It might be camera angle.
Old Jul 1, 2024 | 10:37 AM
Same shifter assembly but the main shifter arm is different between the 2. Is one of those longer than the other ?
Old Jul 1, 2024 | 11:21 AM
If you look at the comparison pics from the bottom view, they appear to be the same. All that's left is installation and testing.
Old Jul 1, 2024 | 11:44 AM
fastsuv's Avatar
In case anyone is looking, these "recyclers" (used to call them junkyards) have some:
Steve
Old Jul 13, 2024 | 07:44 PM
Does the shaft on the right look bent?
Did the Cobalt shifter work in the HHR?
Old Jul 13, 2024 | 09:28 PM
tomasorta's Avatar
hi tbox, at the end both shifter control are compatible for HHR and cobalt? I need to know, because I have similar problem I need to replace the shifter control for HHR 2006, 5-speed, trans-F23. Thanks
Old Mar 31, 2025 | 10:47 AM
tboxx7714's Avatar
Sorry for the late reply. I haven't done the swap yet because I'm trying to find new cables so I can swap it all at once.
If anyone knows where I can find the cables, please let me know. No GM dealer has any leftover stock. I ordered from several dealers claiming to have them only to have the orders cancelled and my money refunded after they didn't actually have the part.
I tried the ones listed on Amazon but the pin diameter is different and they won't go into the receiving clips on the shifter.
