Maybe Thermostat Issue?
Old May 3, 2022 | 02:36 PM
Way back when, I remember some hot rod buddies complaining about their Corvettes running hot, then had put a 195 degree thermostat in place of the 180 that their car came with, the engine management system went nuts!
Old May 3, 2022 | 03:55 PM
jimvw's Avatar
Had the same symptoms last fall, changing the coolant made a huge difference. I still have a replacement cooling fan that may or may not get installed, but temps are running right around 195-210 (when I park and leave it running a bit) Change out the coolant...
Old May 20, 2022 | 10:56 AM
OKIE SS's Avatar
Cooling Fans Do Not Come On
2008 HHR SS with just over 101,000 miles. Seems the car has been running, what I consider, hot lately - 199 -215 mostly in light traffic. Lately, it's been creeping up to the 220s but will eventually cool back to 200 or so with traffic moving. I just checked in my garage to see if the cooling fan was working at all. After about 2 minutes I turned on the A/C, no fans. Let it run about 10 minutes to get temp up to 203 with A/C on and still no fans. Could it be the fan itself or the fan control module? Or should I just "be safe" and replace them both?
Old May 20, 2022 | 11:09 AM
I’d change the fan and module assembly to be sure it’s fixed, it is 16 years old!
https://www.rockauto.com/en/catalog/...+assembly,2181
Old May 20, 2022 | 11:18 AM
Yep, change the whole assembly. Like Oldblue said, it's old. Do you really want to be driving, and wondering if the old part is going to fail, potentially ruining your engine?
Old May 20, 2022 | 12:04 PM
fastsuv advised this in another thread , why take a chance.
And my line of thinking is , have think about replacing the thermostat, AC Delco 131-158 180 degrees.
drain and replace the Dexcool, 50/50 mix with potable water, I prefer the premixed ( getting lazy in my senior years!
think about how old that rad is! It might be time for a new one , cooling fins deteriorate, coolant tubes get weakened!
Then you could leave the water pump till your next time you replace the timing chain!
Old May 20, 2022 | 12:13 PM
Threads merged.
Old May 20, 2022 | 12:30 PM
OKIE SS's Avatar
I appreciate the quick response. I figure it would make sense to change them both since I understand the control module plugs into the fan assembly. Probably time for a thermostat and coolant change as well.
Thanks!
Old May 20, 2022 | 02:42 PM
Remember get the correct thermostat! And don’t forget the discount code if you’re ordering from RockAuto
Old May 20, 2022 | 05:15 PM
PulpFriction's Avatar
The original LNF in my SS ran at 194*, At the time, I thought that was normal.
My new engine runs at 180*. The one time it got hot was when the cooling fan went bad.
My 2010 SS fan doesn’t come on until the coolant shows about 194 on the DIC. That’s with the A/C on. Doesn’t go much higher.
Don’t know if it’s different with the A/C off. Manual trans if it makes a difference.
