Chevy HHR Network
-   -   Mechanic in LA/Hollywood (https://www.chevyhhr.net/forums/problems-service-repairs-42/mechanic-la-hollywood-63298/)
Squinn Jun 27, 2020 06:05 PM
Can anyone refer a Mechanic in LA/Hollywood area. My Son’s 05 HHR has Charging system light on. Battery is newer. Had it to Dealer & said it fine. I know there is a trick to replacing the alternator.
RJ_RS_SS_350 Jun 27, 2020 06:15 PM
Very easy job. The hardest part is getting the belt on & off, still very easy. Remove some of the plastic expansion anchors, maybe a small screw or two from the right front splash shield. Jack up the right front side of the car, support with Jack stand. Pull back the splash shield a bit. Then refer to post #40 in this thread. https://www.chevyhhr.net/forums/www....page=4&t=31446
firemangeorge Jun 27, 2020 06:30 PM
Welcome Squinn
FYI. No 2005 HHR's. 1st year was 2006.
Oldblue Jun 27, 2020 07:41 PM
Welcome to the site, the alternator is fairly easy to replace, as mentioned above
Squinn Jun 27, 2020 08:34 PM
My Bad. Bought it for him in 2005
RJ_RS_SS_350 Jun 27, 2020 08:36 PM
But first, you should let your auto parts store perform a free battery load test and charging system test.
Squinn Jan 26, 2026 04:32 PM
Mechanic in West Hollywood
Any recommendations for a Mechanic in the West Hollywood Area? My son a 05 HHR THAT HAS A P0300 code.
I think he maybe needs coil pack & Cam sensor from a stalling issue. Thanks !
donbrew Jan 27, 2026 09:24 AM
Still no such thing as a 2005 HHR.
P0300 usually has something to do with the timing chain.
Oldblue Jan 27, 2026 10:48 AM
Which engine is in your 2006 HHR? A P0300 code just acknowledges there is a misfire detected.
PulpFriction Jan 28, 2026 10:59 AM
Curiosity alone has me following this.
