Misfire code p0304
Old Jan 9, 2014 | 09:57 PM
Lucky's Avatar
I like using the vacuum hose at the brake booster. The hose end by #2 on the figure below
Old Jan 13, 2014 | 08:37 AM
I pop the PCV hose off of the valve cover.
Interesting that that TSB is NOT for the 2.2L, but every other one.
Old Jan 13, 2014 | 11:50 AM
hurst2001's Avatar
thanks don brew is this the hose that connects to the throttle body and valve cover ? any pics? I want to clean the intake and valves,and also the crank case with sea-foam thanks...
Old Jan 13, 2014 | 01:42 PM
Yes, from the valve cover to the air horn. That bit of plastic is just an elbow, not a valve. I figured it cleaned the TB on the way in. I could not think of any reason to worry about which side of the butterfly it got in on.
Be sure to securely re attach the hose to the valve cover. A loose one can cause OBDII codes for "too lean" etc.
Old Jan 14, 2014 | 12:45 PM
hurst2001's Avatar
Ok last question when i pull the hose off then start the car and pour it in slowly? just like when you use brake booster hose correct....
Old Jan 14, 2014 | 04:11 PM
YES, while your lovely assistant keeps a foot on the gas pedal, revved up to around 2K, IIRC. Look at the seafoam.com site for exact directions.
You need the lovely assistant because the drive by wire won't let you hold the butterfly open by hand.
Old Jan 14, 2014 | 07:07 PM
hurst2001's Avatar
Thanks don brew will do
Old Jan 20, 2014 | 01:10 PM
hurst2001's Avatar
Ok update i have not did the sea-foam yet but i had my battery replaced Friday, it was 6 half years old well since three days have pass no check engine light yea ! So after when i load test it when it was warmer it was marginal ,so my theory is when it got colder and after the car sat all night ,when trying to start maybe it was just getting by but not enough juice and turn on the check engine light for some reason if it possible the motor is idling a little smoother too just kind of weird i say... But problem fixed just passing this on
Old Jan 20, 2014 | 09:36 PM
hurst2001's Avatar
Well guess what its back started it last night with remote start and ran until i open the rear door and shut off and it did it once before ...p0304 this is crazy so next going to run sea foam thur it and see if that works,just thinking if i have a intake gasket leak ?i have check the plug on cylinder no indication of dex cool on the plugs ...just weird only does it when cold ,these is just driving me crazy..
Old Jan 21, 2014 | 09:03 AM
I don't remember if you already switched injectors around.
That would be intake gasketS, there are 4 of then they are rubber O-rings. Maybe check the bolts. But, I think you are heading towards internal problems like rings or valves.
