misses under full throtle
I have a 2009 HHR SS 5speed. When I reach 4000rpm the egine misses or stumbles. Does this from 1st gear too 5th. If you let up it stop. Other then that car runs great. I have no engine codes. Or trouble codes, no lights on. Does anyone have any suggestions for me to do or where to start looking?
thanks |
It could be a number of things, how many kilometres on the odometer?
Have you gone to get a code reader connected to your SS there might be pending codes. |
Agree, if you haven't actually checked for codes, do so. Just because the CEL isn't lit, doesn't mean there are no codes.
If there truly are no codes, start by looking for vacuum leaks and boost leaks. It could also be ignition related, or poor fuel pressure. But all of these usually set codes. |
I was also thinking a dirty throttle body
Originally Posted by Oldblue
(Post 830493)
How old and what plugs are in it?
If the computer is not registering a misfire you are not missing. Look at fuel starvation.
