Low beam went out?
Old 03-17-2016, 10:57 PM
hhrumadbruh's Avatar
Low beam went out?
I replaced the bulb twice and low beams still do not work...what can I do to find out why? Only on left side.
hhrumadbruh is offline
Old 03-18-2016, 12:01 AM
From your owner's manual, check fuse # 65 in the underhood fusebox.
RJ_RS_SS_350 is offline
Old 03-18-2016, 08:17 AM
And check and clean the ground wire connection, also inspect the headlight connection plug, they can deteriorate over time
Oldblue is offline
royperry
01-26-2019 08:13 AM
hayesraven
03-15-2015 09:57 AM
skyeglen
12-29-2013 12:53 PM
iuvenesco
04-10-2009 12:27 PM
larryv
07-10-2007 07:27 PM
Quick Reply: Low beam went out?
