My HHR has a rough idle/misfire
Old Nov 5, 2025 | 11:16 PM
  #31
Kade082's Avatar
Originally Posted by Oldblue
Refresh my memory, was a cleaning of the throttle body and the MAF sensor discussed?
The throttle body was replaced about 100,000 miles ago with Bosch. I cleaned the MAF and MAP sensor. The throttlebody looks fairly clean too.
Old Nov 5, 2025 | 11:17 PM
  #32
Kade082's Avatar
If the car suffered from deferred oil changes in the past, it could have some sticky rings that would explain the wildly divergent compression test results. But that would also cause some oil consumption. Is the car burning any oil?
it burns about a quart to a quart and a half in between oil changes
Old Nov 6, 2025 | 06:28 AM
  #33
Check the elbow at the throttle body, is the hose from the valve cover clean? Or does it have oil residue in it?
Old Nov 6, 2025 | 10:16 AM
  #34
PulpFriction's Avatar
Sticking rings would explain the wildly divergent compression results better than cylinder wear. To free possibly sticky rings, you could put 1/2 to 1 quart of ATF in the crankcase, run it for 50-200 miles, then change the oil. There are products for that purpose, too, if you prefer. Then, you could do a compression test again, or just wait and see if the oil consumption and other problems improve.
You Might (re?) test for intake leaks.
Did you ever say exactly which spark plugs you used? You need ACDelco 41-103 (iridium.) No substituted. No “just as good.” No “made by the same company.”
Old Nov 6, 2025 | 10:22 AM
  #35
I had some success unsticking rings with Seafoam top cleaning. There are other "top cleaners".
You basically pour an ounce or 2 in each spark plug hole and let sit over night then expect to see copious amounts of smoke when you stat the engine.
Old Nov 7, 2025 | 06:53 PM
  #36
Kade082's Avatar
There is a little bit of oil coming out of the breather valve on the valve cover.
Old Nov 7, 2025 | 06:58 PM
  #37
Kade082's Avatar
Yes those are the spark plugs that I installed. My teacher is going to do a smoke test and check for vacuum leaks and the intake and exhaust.
I might eventually put ATF in cylinders. I'm putting seafoam in the crank case before every oil change.
Old Nov 7, 2025 | 07:03 PM
  #38
Kade082's Avatar
What codes exactly? All of them.The numbers, not descriptions.
The only ones that are coming back are P0172,P0300 And sometimes P0011,P0014.
Old Nov 8, 2025 | 07:15 AM
  #39
Address the P0172 first, here’s some information
https://www.obd-codes.com/p0172
Then the P0011
https://www.obd-codes.com/p0011
Then the P0014
https://www.obd-codes.com/p0014
Most likely cause is a cracked exhaust manifold or flex pipe and dirty MAF sensor
The timing issues are most likely dirty malfunctioning VVT solenoids. The P0300 is caused by the timing issues.
Old Nov 8, 2025 | 09:12 AM
  #40
Oil coming out of the breather indicates ring problems.
