Need to adjust rear hatch latch oer striker
Searched but can't find too much on this. My rear hatch has a rattle and I want to adjust either striker or the latch . before i start removing plastic has anyone done this ? which one or are both adjustable?
Thanks |
Before you start adjusting this latch I suggest you get some good grease and lube it.
Note that the latch lube should not go on the top of the floor U striker but on the part of the U bar that faces toward the rear of the HHR. Thats where the latch contacts the U Bar. SF |
Adjustment is done with the 2 pillow blocks on the sides of the opening. you loosen it them up and try for fitment then tighten back up.
Originally Posted by donbrew
(Post 699472)
Anyone know if its a torx bit and what size that holds the bottom hook striker down. Have to replace mine, oddly the only thing thats rusty on mine.
Originally Posted by Trex08
(Post 821260)
Chevrolet HHR Hatchback LIFTGATE HARDWARE PART 1 http://www.wholesalegmpartsonline.co...121T12-033.JPG |
Thats the one. Xlnt thanks.
Rear hatch
The pillow blocks will tighten it up, but the problem that I have, is that the hatch doesn't pull in enough. I have wind noise in the back seat. I need the hatch to be tight AND seal properly. Any Ideas on that?
Thanks |
1 Attachment(s)
If adjusting the blocks and the hinges and the latch don't work the gasket may need repair/repositioning/replacing.
Attachment 21361 |
