Need help with my dome light
Hello everyone,
I am going crazy trying to find a new replacement on my rear cargo dome light housing. I've looked everywhere on the internet and no luck. My problem is the switch slides back and forth and it doesn't make contact with any of the metal contact points inside, so the light never turns on. I pulled down the whole housing and it looks like some piece of metal fell out or the contact points simply wore out, either way I can't seem to find a way to fix it. Any help locating a new housing or someone can explain to me how they fixed their light would be great. Thanks |
have you checked rockauto . com ?
Here's the parts diagram and numbers from Nalley, you can see what you need and then cut and paste the part numbers into the search function at Rockauto.
http://parts.nalleygmc.com/showAssem...&searchString= |
BeanWagon,
I'm sorry you are having this problem with your vehicle. Have you taken a look at http://www.gmpartsdirect.com/ ? You should be able to find what you're looking for at this site. Please let me know if you need anything else, thank you. Evan, Chevrolet Customer Service
Originally Posted by BeanWagon
(Post 609859)
Hello everyone,
Thanks for the help everyone. With the Nalley diagram I was able to find itthe part number and then I tracked it down on Gmpartsdirect.com.
Thanks again. |
