need help with p2122 code
The sensors are in the foot pedal, look for loose wires in the harness connections and give the throttle body a proper cleaning, with the correct TB spray cleaner, remember do not move the butterfly manually, you might strip the plastic gears in it!
I simply remove the air filter assembly, then unbolt the throttle body lift it up and turn it 90 degrees, and give it a spray of this.
And this in the throttle pedal connections
DASH0071972@
23
07-01-2015 12:31 PM
