Chevy HHR Network
-   -   New Battery Installed Lost Radio and Sounds (https://www.chevyhhr.net/forums/problems-service-repairs-42/new-battery-installed-lost-radio-sounds-57968/)
m_ridzon Aug 22, 2025 04:07 PM
Folks, I just found this old thread. My SS seems to be having this exact issue. I disconnected the battery for something completely unrelated to the radio. After reconnecting, the radio is completely dead. Fuse #23 seems fine. Was there any final resolution to the situation in this thread?
RJ_RS_SS_350 Aug 22, 2025 04:30 PM
For clarification, your issue is more then just no sound, you also have nothing lighting up the radio display?
m_ridzon Aug 22, 2025 04:35 PM
Correct. I have no audio. I have no display on the radio. I push its center button to power on and get nothing. The car starts and drives fine. But the radio is completely lifeless. And today's battery disconnect was not intended to affect the radio at all.
Oldblue Aug 23, 2025 07:10 AM
I had that issue, there’s a few companies that will revive your head unit , some internal circuits need to be repaired. Or just get a replacement radio from where ever you like. Crutchfield has the adapters and brackets.
m_ridzon Aug 23, 2025 07:15 AM
I'm really perplexed as to what could have damaged the radio. This is not the first time I have disconnected the battery in this car and the radio has been fine each time. Do you know the names of any of those companies?
firemangeorge Aug 23, 2025 08:35 AM
The fuse seems “fine” ? Did you actually check it with a meter ? Does it have power on both sides of the fuse ?
If yes, then your next step should be to pull the radio and check for power to it at the plug in. No sense in buying a new radio if there’s no power at the harness.
Oldblue Aug 23, 2025 09:58 AM
This is one still in business
https://www.1factoryradio.com/collec...rolet-hhr-2010
m_ridzon Sep 23, 2025 05:44 PM
After some checks tonight, it looks like my radio is officially dead. The hot and ground to the radio is fine, telling me the damage is internal.
m_ridzon Sep 25, 2025 09:35 AM
Originally Posted by Oldblue (Post 872581)
From what I’ve gathered , the diode in the radio is toasted.
@Oldblue by chance, did your repair friend tell you what diode was toasted? I'm wondering if I can take it to an electronics guy with that information and have them replace that diode to get it working again.
Oldblue Sep 25, 2025 01:21 PM
I ended up getting a replacement head unit and vin matched it to the car. The burnt radio had internal circuit board issues, wasn’t worth repairing
