Chevy HHR Network
-   -   No coolant temperature and air blowing warm (https://www.chevyhhr.net/forums/problems-service-repairs-42/no-coolant-temperature-air-blowing-warm-47494/)
JamesCardoza Aug 15, 2013 06:13 PM
I don't think it's overheating, my drive home and to work was normal, just the water temp all the way and coolant temp at "---"
donbrew Aug 15, 2013 06:33 PM
Originally Posted by JamesCardoza (Post 716603)
Top off on coolant?
Should only lose about a pint. Make sure the Pressure System is full, not just the tank. Never mind the last sentence, if this is a 2006.
blacky Aug 15, 2013 08:12 PM
Originally Posted by donbrew (Post 716599)
Or the engine is over heating. Either one does the same symptom. without the actual code ...... However, over heating should cause "limp home" mode.
You don't really NEED to drain the system, just capture what comes out and top off.
Wait a minute. donbrew, are you saying that both overheating and too slow of a warm-up yield: the ' ... ' digital temperature reading, temperature gauge pegged cold, and no AC? Are you kidding me! Have the GM engineers lost their %%&&& minds!
JamesCardoza Aug 15, 2013 08:52 PM
Will it harm the coolant system if I don't replace the radiator fluid? The dealership had already flushed and replaced all fluids before I bought it
whopper Aug 15, 2013 09:40 PM
Of course not - it is totally reusable. You can drain it low enough to pop off the thermostat housing - drain via the drain petclock on the bottom backside of the rad. Just collect it in a small bucket. Then when the thermostat is replaced, pour it back in.
If you got a CEL lighting up - you need to get the error code via a code reader - hit up an auto parts store who should read the code for you for free.
Lastly - when someone asks you if your A/C is disabled - please don't reply "no, it's blowing warm air"- you need to reply "yes, it's blowing warm air" - it confuses those that don't read internet. :-)
whopper Aug 15, 2013 09:50 PM
No, and no.
JamesCardoza Aug 15, 2013 10:45 PM
Haha I completely understand, I'm a new and learning "car guy" so a lot of times simple car concepts are foreign to me. Also a musician for what it's worth ;-)
Anyway, my buddy Matt came over tonight and we replaced the thermostat, and topped off the radiator fluid. Ran the ac hot until it was hot to touch, and all was well.
Just for kicks too, I disconnected the rear battery to rid myself of the CEL, and now I can also remote start the vehicle as well.
Very happy man I am now!
Now the next thing to do is get the new power steering assist motor and we'll be good to go!
whopper Aug 16, 2013 12:30 AM
Good deal man!!! When I replaced my thermostat, I set the Digital display to the temperature display and watched the temp rise as the engine warms up - it's semi-interesting from a nerd point of view. LOL
donbrew Aug 16, 2013 02:19 PM
Well, when the car goes into "limp home" mode the temp does indeed go to ---. At least my 2008 did after the temp got over 241 F, more than once just before shut down. I don't fault engineers for that, as you should not really care what the exact temp is if there is copious amounts of steam under the hood. It is called "overload".
