No injector pulse
No injector pulse
Ok so I have a 2008 hhr started loosing power and died got it started back and ran with low power for just a few minutes and died and wouldn't start back the temperature gauge reads hot but it's not running hot towed it home turned the key on temperature hand went straight to red and says cool down mode so replaced sensor and the same thing with the new one so not sure if it's the reason it won't start but got to checking stuff have fuel pressure and spark but no injector pulse with noid hooked up.the temperature gauge will bounce cold to hot if u leave the key on for a little while but it never stays on cold just returns to hot every time
