Power steering stops while I'M driving
Old 07-13-2013, 07:06 PM
CHHHR09's Avatar
Why would my power steering just stop as I am driving and then after I put it in park and restart the engine reset and then turn off again? I already replaced the fuse for the EPS.I have a 2009 HHRLS, This happened 4 times today and I never had a problem with this car in 4 yrs...I love my HHR.
CHHHR09 is offline
Old 07-13-2013, 07:58 PM
Lucky's Avatar
May have a power steering motor failing. How many miles on the car? Was the eps fuse blown?
Lucky is offline
Old 07-13-2013, 08:00 PM
Technical Moderator
Known issue, overheating EPS motor. Check with your GM dealer service dept., it may be covered.
donbrew is offline
Old 07-13-2013, 08:26 PM
jay loukakis's Avatar
The only thing covered by the Stealer is your check book.
jay loukakis is offline
Old 07-15-2013, 01:01 PM
More_Torque_More_HP's Avatar
I have the same thing on a 2006. Power steering does not work. it would work if I pulled the fuse and put it back in. Now it out 100% of the time. I searched for answers but there is not a clear concise solution I have found. If some one has found a solution please post.
More_Torque_More_HP is offline
Old 07-15-2013, 01:33 PM
Actually this has been discussed a lot previously - it's your power steering motor that needs replacement. There is a "How-to" article on replacing it - it's a good writeup - and is easy to do, and the parts are cheap.
whopper is offline
Old 07-15-2013, 04:31 PM
I apologize that you are having these frustrations with your vehicle. To better assist you could you please private message me your name, address, phone number, vehicle identification number, and current mileage?
Thank you
Jessica L.
Chevrolet Customer Care
ChevroletCustomerService is offline
Old 07-15-2013, 06:09 PM
prod's Avatar
In canada this has been addressed by a special 10yr replacement plan on some vehicles by VIN, US may be different. The electric power steering motor has a thermal shutdown feature, when the motor gets too hot it shuts off temporarily. This may be due to failing motor.
prod is offline
Old 07-16-2013, 09:05 AM
Could you send me the link. I searched and looked at some possibles but nothing was clear to me on what needed to be done and with what parts.
Old 07-16-2013, 09:16 AM
walkowg's Avatar
I guess the motor thinks it need ac LOL
walkowg is offline
Quick Reply: Power steering stops while I'M driving
