No power to fuel pump
Old Dec 23, 2024 | 06:32 PM
Lilgaycarowner's Avatar
I'm having electrical problems to the fuel pump on my 2009 HHR lt. I've checked the relay and the fuse I hotwired the fuel pump and it works just fine. Can anybody help me?
Old Dec 23, 2024 | 08:02 PM
Any lights on the dash?
Same key as always?
Power to the relay?
Signal on the relay control?
Old Dec 24, 2024 | 06:37 AM
Is the plug for the fuel pump clean and connected firmly? Its under the car rear axle area , passenger side, look for rodent chew marks
Old Dec 24, 2024 | 07:07 AM
PulpFriction's Avatar
You know that when you turn the key on, the fuel pump is only powered for a couple seconds, right?
Old Dec 24, 2024 | 12:07 PM
I have taken my rear seats out and probe the gray wire with power it works.
Old Dec 24, 2024 | 12:40 PM
You can't do that on an HHR. What car is this?
Old Dec 24, 2024 | 12:41 PM
It is an HHR if you lift the rear seats and pull back the carpet there is a wiring loom and the fuel pump wire is one of those.
Old Dec 24, 2024 | 12:50 PM
The fuel pump only runs for about 5 seconds without the motor running.
Did you see post #2? What are the answers?
Old Dec 24, 2024 | 01:28 PM
Great now check the harness connector under the car
It should not have green crude in it.
Old Dec 24, 2024 | 04:30 PM
The car will not start The fuel pump will not run Crank it no start there's no power going to the fuel pump at all I have tested the fuel pump it works fine I pulled up the back seats and probe the gray wire with power The fuel pump will run it's not the ground. The car will not start after I hook the fuel pump back up.
