No start
Old Jun 12, 2018 | 11:38 AM
Clayton Wait's Avatar
Angry No start
HELLO.
08 HHR starter will not work with key, replaced the starter switch still no start, I can jump the starter relay and it will start right and run fine. but will not turn over using the key .When I turn the key on all dash light come fuel pump kicks in every thing works just no starter...
Old Jun 12, 2018 | 12:29 PM
Cat Man HHR's Avatar
How old is the battery?
Old Jun 12, 2018 | 01:22 PM
hurst2001's Avatar
your security light on ?
Old Jun 12, 2018 | 04:19 PM
Uh, when you jump around the relay it works. Doesn't that give you a hint?
Old Jun 12, 2018 | 04:52 PM
No
Give me a hint..no it dont..... I know theres no key power going to start relay when the key is in start mode....by pushing the contact in relay jto to crank it just tells me the wiring from relay to starter is good.....does key power from switch to to bcm before the starter relay?
Old Jun 12, 2018 | 05:49 PM
Then exactly what do you mean by "jump the starter relay".
The system is NOT like your 1959 Chevy. There is no wire between the BCM and the relay, there is a serial data link between the BCM and the ECM.
For your edification:
Old Jun 12, 2018 | 11:16 PM
No start
Lol well never seen a 1959 use relays... You can jump any relay but like i said in last post i can push the contacts of the relay and make it start....the relay has 12 batt and leg is ground and one leg goes to what ever the relay used for and other leg is switch power. Correct?... I didnt ask if there was anything between between the relay n bcm.......but buy you reply the relay gets it start feed from bcm...thats what i was asking. Ty
Old Jun 13, 2018 | 07:34 AM
The wiring diagram and schematic I posted should show where and what to test for.
My guess is the neutral/park switch if there is indeed no power on 85 or ground on 86.
BTW; 12V is a dead battery, should be closer to 12.6-14.2.
Old Jun 13, 2018 | 07:49 AM
I’m thinking dead battery or at least a cell or two, mine was pronounced dead at 12.5 volts
Sammy_SS
Mar 6, 2017 11:30 PM
HillsdaleHHR
Feb 21, 2009 02:26 PM
dbowers
Dec 7, 2005 04:27 PM
SIHHR
Nov 19, 2005 05:49 PM
adamlowery
Nov 18, 2005 02:04 PM
