No tail lights or radio lights at night
Recently my interior center LED light and radio lights stopped working at night, plus thanks to a helpful cop, I discovered that my tail lights were no longer working either. Does anyone know which fuse handles all of these items?
They don't work even if I turn all my headlights on manually. Thanks |
Since you didn't give any info on your car(year,model) I'll take a stab at this.
Under hood fuse box:Fuse #69-Parking Lamps Relay #68-Parking Lamps |
Beat me to it George, check those first datekman.
P.S. :welcome8: to the forum! |
Sorry about the lack of details. It's a 2007 HHR. I'll give those a check first. Thanks.
There is also a couple grounds in both rear corners and one of the ones on the passanger rear corner will kill the rear lights if not connected.
Originally Posted by 07azhhr
(Post 646124)
i have replaced 68 and 69
turn on the lights the tail lights still do not work. the center radio console lights come on and after about 10-15 seconds go off again i saw another thread that said the ground in the rear corners where are those grounds in the rear area of the motor compartment or in the rear by the tail lights. |
i replaced the relay the fuse looked good when i pulled it did not have a lamp or a meter to check it. another thread says ground locations in the rear corners and the rear corner group on the passenger side will kill the tail lights. do you have a visuaL of what he is talking about in the rear corners.
Operation CHARM: Car repair manuals for everyone.
Home >> Chevy Truck >> 2007 >> HHR L4-2.2L >> Repair and Diagnosis >> Diagrams >> Grounds >> Master Grounds List Master Grounds ListG103 - G403:https://charm.li/images/DM13Q313/gm61/780959908/pro multis · About Operation CHARM |
