Noise that sounds like a hub bearing
Old Nov 14, 2018 | 05:27 PM
Cat Man HHR's Avatar
Hi
2010 SS auto with 51K.
Have a "hub bearing" noise. Jack up each side and no play or noise as you rotate the wheels. Check the backs also and they are fine. It does sound like a bearing, the faster you go the faster noise and volume of it. It sounds like the front right to me. No shake or shimmy. No vibration like an out of balance wheel/tire.
Don't have access to a lift to really get a look at axils. Looking from under the car there are no leaks, like a bearing in the transaxle is bad.
I tried to Google this and can't find an answer. There is no clicking noise as you make a turn which would indicate an outer CV joint bad. Don't know how to prove out the inner. This might be a possibility. And if the axle is bad which axle do I buy? As the SS has no parts available.
I did read on this forum there are two you can use. One a little shorter and one a little longer.
Thanks
Old Nov 14, 2018 | 05:54 PM
The inner is not a bearing per se. It is a tri-pot that provides lateral play
Old Nov 14, 2018 | 06:02 PM
Trust your gut, at 8 years old and 51,000 miles , it’s a safe bet it’s the hubs
the obsolete axle problem has been addressed, I think with Detroit Axle.
How worn are the brake pads? Are the little tabs scraping the rotors?
Old Nov 15, 2018 | 03:27 AM
Brake pads are good.
Hub were rocked at positions 3&9 also 12&6. Both ways are tight. Spun L&R wheels by hand didn't hear anything. Had a buddy recheck what I did and he found nothing also.
Going to do this:
Old Nov 15, 2018 | 05:57 AM
Lethal Tendencies's Avatar
Most likely bearing. Especially if it increases with speed
Old Nov 15, 2018 | 06:16 AM
[QUOTE=Cat Man HHR;855711]Brake pads are good.
Going to do this:
Just don't do like Eric the Dangerous car dude and jack it up by the frame with the suspension hanging.
Old Nov 15, 2018 | 06:30 AM
[QUOTE=firemangeorge;855715]
I want to jack it up and support it by the lower arm.
In his video he might be jacking it up by the lower arm, but it's not clear if he did so.
Old Nov 16, 2018 | 05:24 PM
Blue_SS's Avatar
You can't always feel it that way. I don't have the spec handy, but the runout allowed is tiny. Eventually, you WILL be able to feel it that way. A good pothole strike can ruin a hub bearing though.
Old Nov 16, 2018 | 05:30 PM
True that! Pot holes can kill a brand new hub.
Old Nov 17, 2018 | 11:22 AM
And other stuff too.
Just checked again today to make sure I wasn't nuts. And again rocking did not show play and ball joints were tight.
Jack up each side one at a time and supported lower arm and spun them up. Much to my surprise I thought the noise was on the right but it turned out it was the left.
Replacement will be on Monday. The company that I use to work for said there would be no problem for me to come down after working hours to use the shop.
That makes me feel warm and fuzzy. Dry, heated and flat floor when outside is not nice. They only have a portable lift for large gross weight units. Oh well.
