Originally Posted by Dutch
(Post 694880)
I have this exact issue with my 2007 HHR LS and the funny thing is that the leak appears to originate from where the motor mount meets the frame. If there is not a hydraulic mount what else can it be? I checked everywhere around the engine and it is clean.
Check your axle seals. I had one side leaking, looked like it wasnt seated all the way. Took a flat head screwdriver and hammer and lightly small increments tap the the metal part of seal inward and no more leaks. Becareful you could damage seal. For me was a quick fix. I called the dealer for axle seal replacement $150 bucks one side.
