Oil Life Indicator Reset Itself...
for no apparent reason and without human intervention. No trouble codes in the ECU. My scanner cannot access any data from or about the BCM. Anyone have any ideas?
I know that is supposed to work on the HHR, does it?? On my 2002 Silvaerado Diesel that is the only way to reset the Change Oil indicator. It usually takes me about 10 times before I can get it to work!
Thank you....that is much better. And I do agree with the above post. The tech or "grease monkey" did not reset the OLI.
If you did not know....the Oil Life Indicator (OLI) does not reset by itself. It must be reset by a person. The protocol is in your Owners Manual or you do the "quicky method" .....3 pumps.
Also you should read the portion that relates to the OLI and how it works. It might eliminate some confusion. Oh and it does NOT indicate low oil.
