Chevy HHR Network
-   -   Oil in spark plug well (https://www.chevyhhr.net/forums/problems-service-repairs-42/oil-spark-plug-well-49681/)
rickschr85051 Feb 28, 2014 09:38 AM
I recently changed my plugs @ 62000 miles and discoverd some oil in the plug well, has anyone seen this? I was also wondering if my plug boot could be effected by oil inside of it? Thanks
whopper Feb 28, 2014 09:44 AM
It happens. Most likely it's the gaskets around the spark plug wells under the valve cover that need to be replaced. Not a major repair nor expense. The spark plug boot should just need a cleaning and will most likely be just fine.
Lucky Feb 28, 2014 10:28 AM
X2:thumb:
Oldblue Feb 28, 2014 04:00 PM
X3!!
donbrew Feb 28, 2014 06:08 PM
X3. The valve cover gasket is actually a multi-piece thing with O-rings at the spark plug holes, if it has ever been removed somebody may not have replaced them correctly.
rickschr85051 Mar 3, 2014 09:20 AM
Thanks for the info!
badassbowtie Mar 3, 2014 04:51 PM
A sloppy oil change is very likely too!!!
