p0011
ok a few weeks ago I was getting a P0011 code from engine light.
changed oil and filter light went away, engine light came on this past Friday morning. today I changed intake and exhaust cmp solenoids and air filter with first start up light was off, than it came back on with service esc on speedometer taking a break and reflecting a few moments guess I need to go and get code read again for engine light and go from there. |
Bet you forgot to plug the MAF back in.
Originally Posted by donbrew
(Post 778127)
it took away all readings of esc... service, no . i'll ride to store tomorrow and get it scanned again |
Are you using Google Translate?
That made absolutely no sense. |
no I am not LOL.
Yes , I had left it unplugged. I had problems installing the air filter housing. but after plugging it back in, I still have the engine light on |
Try a few trips first then have the codes read then cleared!
You will probably have about 4-5 weird codes that will clear themselves after 3-4 cold starts.
I just did that today. |
or...... try disconnecting the negative side of the battery for a few minutes to clear the existing codes and start all over.
up date have dropped off at shop this afternoon- don't have time <with work> or knowledge will let you know what happens
UPDATE all is well.... I broke a wire on the exhaust solenoid.......when I took the wires off.... all is well now |
