p0013 and p0014
Old Nov 10, 2014 | 07:47 AM
dkennedy1282's Avatar
p0013 and p0014
I had a p0013 code on my wife's 2010 hhr. I replaced the exhaust vvt solenoid, and cleared the code. Everything seemed fine but after a hard start, it is now throwing a p0014 code. I did an ohm test on the solenoid before replacement. (do not remember the exact values but determined it was bad through this) PLEASE HELP!!! I. at a loss and have hit the wall on this car. Runs fine, just have an engine light that won't go away.
Old Nov 10, 2014 | 08:20 AM
I don't understand your dilemma. They are different codes for different faults.
P0013 is intake. P0014 is exhaust.
Old Nov 10, 2014 | 08:35 AM
I've read up on both codes and from what I can find, the same part could be at fault for either code. My dilemma is, that I do not know where to go from here. p0013-"B" Camshaft Position Actuator Circuit (Bank 1) p0014-"B" Camshaft Position - Timing Over-Advanced or System Performance (Bank 1). Why would p0014 come on after p0013 was fixed?
Old Nov 10, 2014 | 08:42 AM
Both refer to the "b" or exhaust side
Old Nov 10, 2014 | 08:59 AM
What about the camshaft position sensor ? Not the solenoid.
Old Nov 10, 2014 | 10:46 AM
no big deal, but Donbrew was a little off on the codes vrs exhaust (it happens):
P0010/11 refers to the INTAKE solenoid
P0013/14 refers to the EXHAUST solenoid
So you replaced the right one.
Some questions for you:
Did you disconnect the negative post of the battery for a 15 minute period to reset the code?
If you did, are you sure you got the connection at the top of the solenoid re-plugged ok - and did not damage it trying to disconnect it during the replacement (that clip is a pain)?
Did you get a genuine GM replacement or an aftermarket one?
Old Nov 10, 2014 | 12:34 PM
Sorry about pre coffee mistake.
One could show up after the other is fixed because one was masking the other or a wire got messed up in the repair process.
Old Nov 10, 2014 | 12:37 PM
Oh tell me about the coffee thing - I'm just finishing the first pot here. LOL Gotta get a kick-start in the morning.
Old Nov 10, 2014 | 03:15 PM
Thank you all for the replies.Donbrew, I'm all too familiar with pre coffee mistakes. I did not disconnect the battery. Maybe that was the problem. I'm sure that I replaced the right solenoid, as it is stamped IN and EXHAUST on the valve cover. I have another solenoid and will make sure to disconnect the battery tonight when I do it. Thanks again everybody. I'll update tomorrow
Old Nov 10, 2014 | 05:20 PM
Keep us informed so we don't get all uptight and fidgety, man Juan Veldez is a great man!
More coffee , please!!
