Problems/Service/RepairsIf you have a problem with your HHR, want a tip on repairing or performing a particular service to you HHR here is the place to post!
The borescope is arriving tomorrow, so I'll be able to look into the cylinders and get some pictures of the internal condition. Here's to hoping that there's no damage and is only needing a new chain and guard.
The only time I would waste my angst on is if the chain catastrophically flew into pieces at high speed. Definitely not when it just skipped a tooth or 2.
Out of all the talk about "interference engine" I only recall 1 instance here that a valve damaged a piston and itself from a chain breaking.
Alright, scope came in today and I just finished taking some pictures in each cylinder. I took a picture of the top of each piston (as best as I could due to their position) and a video looking as each of the valves in their current positions. Honestly, to me they look pretty good but I'd always appreciate a second opinion.
I'll follow up with links to the videos for the valves. Cylinder 1 Cylinder 2 Cylinder 3 Cylinder 4
I just changed them but not, they were all pretty toast when I removed them. But, I wouldn't doubt a coolant leak in the cylinder bc I've had to top of the coolant recently.
