P0087 = FRP too low
Old Nov 30, 2024 | 03:25 PM
3M HHR SS...'s Avatar
P0087 = FRP too low
So, I bought a 2008 Chevrolet HHR SS/auto transmission = upon dealership delivery, my SS had no issues whatsoever & drove as it should = awesome & fast. Well, me being me = I like to swap out various parts & fluids when I buy a used vehicle.I began with the usual = all fluids & filters/air filters x2/ spark plugs & ignition coils, etc. Even though it didn't require it, I went ahead & installed a new Valve Cover GASKET KIT. Well, after all was said & done = the CHECK ENGINE LIGHT came on when it wasn't on before. My SCANNER/CODE READER came back w/FUEL RAIL PRESSURE TOO LOW! So, as per the SCANNER INSTRUCTIONS = I went ahead & replaced the TANK FUEL PUMP, & the HIGH PRESSURE FUEL PUMP in the engine bay, plus; I also installed a new MASS AIR FLOW SENSOR = Even after doing all that = the CHECK ENGINE LIGHT is still on & my SS still displays the REDUCED ENGINE POWER warning...
I'm looking for knowledgeable answers as to how I should proceed with any further repairs...
The solution my SCANNER/CODE READER says to do = ive already done...
The solution my SCANNER/CODE READER says to do = I've already done...
Old Nov 30, 2024 | 05:35 PM
I would check the actual fuel rail pressure. Not sure of the specs but around 2200 at cold startup and around 400 at warm idle.
Old Nov 30, 2024 | 05:41 PM
I'm working on that as we speak = Hopefully it's something minor = my SS will fix itself for a few minutes, then right back to REDUCED ENGINE POWER WARNING...
Old Nov 30, 2024 | 08:16 PM
Did you look at the wires to the fuel rail pressure sensor?
Old Nov 30, 2024 | 08:26 PM
I'm also checking all the wiring/connections, etc...
Old Dec 1, 2024 | 07:26 AM
Most likely the fuel pressure sensor.
Old Dec 1, 2024 | 09:47 AM
PulpFriction's Avatar
Do you have an RPD? You can look at the fuel rail pressure. Otherwise, you need a scan tool. P0087 and the rail pressure may have nothing to do with the fuel pump. No low-pressure sensor. The only way to look at the pressure from the fuel pump is to attach an external gage.
But you surely messed with the feed to the high-pressure fuel pump and prolly the wiring when you took the valve cover off. (File under if it ain’t broke don’t fix it?)
Old Dec 1, 2024 | 04:31 PM
No RPD on 2008.
Old Dec 1, 2024 | 04:58 PM
I never replace parts just because the OBD II scan tool says so.
Old Dec 3, 2024 | 06:41 PM
Wonder where the OP is ?
