P0090:Fuel Pressure Regulator Control Circuit (HELP PLEASE)
Hello Forum!
I got a 09 HHR SS Automatic and I need help I pulled this code (P0090) at my local autozone and I had my display show up "ENG POWER REDUCED" Im wondering if anyone else has run into this situation and knows how to resolve this.
also the P0090 code. the people at AutoZone said it showed up twice I never heard of a code popping up twice but hey that's why im here
So, my advice is to first call a GM shop and explain the code then ask if it's covered. If it's not then call you insurance co. and ask them.
Either or both may require you to have it in a shop for diagnoses. A GM shop would kill both birds with the same stone. Take it to a professional and find out.
Being that a P0090 code can be any of the following...
- Faulty fuel pressure sensor
- Fuel pressure sensor harness is open or shorted
- Fuel pressure sensor electrical circuit poor connection
- Faulty Engine Control Module (ECM)
You really need to have it checked over by a good diagnostic technician, otherwise you'll end up throwing parts at it.
after some more troubleshooting found something interesting there is a loud buzzing sound coming from the fuel tank I lifted up the car and had my brother listen as I turned the key im not sure is that normal and haven't noticed or just looking for another diagnostic issue
but I will do what was suggested form yall I will call the dealership and see if they can take care of the problem hopefully I wont have to come out of pocket. worst case scenario I will loose about $130 just for diagnose the problem
Hello Forum!
I can for sure look into this issue for you. Could you please private message me you name, address, vehicle identification number, and current mileage. Thanks!
Jessica L.
Chevrolet Customer Care
If it is indeed the fuel pump, it looks like the 2009 Fuel Pump is covered under 5yr/100,000 mile powertrain warranty per post #3 from this thread...
https://www.chevyhhr.net/forums/problems-service-repairs-42/07-09-10-11-powertrain-parts-coverage-list-22231/
nrodwal
Mar 14, 2021 02:12 PM
BLUEHHRSS5SPEED
Dec 19, 2010 08:46 AM
