P0172 Code- Help Please
Old 01-15-2019, 02:30 PM
  #111
Technical Moderator
Somebody a few days ago solved all of their problems by finding and fixing the crack in the PCV hose and the intake tube.
donbrew is offline
Old 01-15-2019, 02:31 PM
  #112
cturboaddict's Avatar
Just text him. It's a Matco Maxme. I thought he had a snap on.
cturboaddict is offline
Old 01-15-2019, 02:32 PM
  #113
I would love for it to be that easy. My road has been rocky thus far.
Old 01-15-2019, 03:24 PM
  #114
I've got the Torque Pro app. Not really sure how you would use that to diagnois a problem like you have. I basically use mine as a code reader.
firemangeorge is offline
Old 01-16-2019, 06:51 AM
  #115
So, here is what the hard start sounds like with the rough idle after the car has been sitting. I have to hit the gas pedal to get it to fire. Just wanted to share with everyone.
Old 01-16-2019, 11:35 AM
  #116
Technical Moderator
Torque pro does do real time readings for most of the OBD2 inputs.
donbrew is offline
Old 01-16-2019, 12:27 PM
  #117
DrLoch's Avatar
is this by chance a flex fuel car?
DrLoch is offline
Old 01-16-2019, 12:40 PM
  #118
yes
Old 01-16-2019, 12:53 PM
  #119
Cat Man HHR's Avatar
I counted about 3 seconds for the engine to start by looking at the tach.. How fast do you think it should start ?
Just a thought but don't know. Could the TPS be out a spec ? That's why you have to hold your foot down to get it to start ? Holding your foot down tells the ECM to have a longer pwm to the injectors which equals more fuel.
Yes I realize if there is a problem with the TPS there should be a code.
Again it's a shot in the dark.
Cat Man HHR is offline
Old 01-16-2019, 01:00 PM
  #120
That's only with me applying the gas. Then it stumbles roughly, then it smooths out.
And remote start won't fire the car after it sitting. It will crank, just no start.
It won't start after sitting without me apply my foot to the gas pedal a bit.
As far as the TPS, possibly. Is there reset for it? I'm hoping the good scanner my buddy has should tell me a bit more.
Quick Reply: P0172 Code- Help Please
