P0341 2007 Chevy HHR 2.2L
Started off with codes P0016,P0068, & P0455!I Took care of those by changing the MAP Sensor and then the Camshaft Position Sensor!I started the vehicle,ran it around the block and the check engine light came on.Then did a reset of the car,not it won't start.Ran FIXD Scan,and now code P0341pops up!What is needed to fix this issue?
P0016 , the timing chain has skipped a tooth, do not try and run the engine, it is a close tolerance engine and you could bend some valves. Not a hard job to change the timing and balance shaft chains
http://www.ddmworks.com/assets/image...uild%20Kit.pdf
It doesn't work for me either. Here is some great information from our How-to forum.
https://www.chevyhhr.net/forums/how-...in-kits-60394/
